Author Topic: What carb do I have?  (Read 1527 times)
Offline peter400four
« on: March 11, 2016, 09:07:49 PM »
Hi all,
I need to replace my float chamber o rings, but I'm not sure exactly which model CB550 motor the carbs are off as the motor was bought for a project without model ID. Can anyone help.
Re: What carb do I have?
« Reply #1 on: March 11, 2016, 09:31:26 PM »
Those are 069A carbs.
4into1.com has replacement viton bowl gaskets.
http://4into1.com/shaped-o-ring-float-bowl-gaskets-4-pack-honda-cb350k-cl350-cb500-cb550/
« Last Edit: March 11, 2016, 09:33:27 PM by flybox1 »
« Reply #2 on: March 12, 2016, 03:34:51 AM »
Thanks for that Flybox.
 I didn't realise it would be as simple as reading the number stamped on the carb, but when you think about it, it's pretty logical.
You wouldn't know what year model they come off, would you?
Regards.
Offline qside
« Reply #3 on: March 12, 2016, 04:43:16 AM »
Motorcycleproject.com has great stuff on carbs
I use this link for my carb reference info
http://www.motorcycleproject.com/text/specs.html
« Reply #4 on: March 12, 2016, 06:41:22 AM »
this is the older type..used to 1976.both 500 and 550..
..77 and 78.k bikes used a newer type..vith a kabel choker and some finer tuning..the older is easyer to Work /mod ..for pods and tuning
« Last Edit: March 12, 2016, 06:51:00 AM by strynboen »
« Reply #5 on: March 12, 2016, 12:30:18 PM »
Thank you for all that tech info fellow forum users. Even I can work out what's what using that.
This forum never fails.
Thanks again.
Offline Kenzo
« Reply #6 on: March 12, 2016, 12:43:07 PM »
I have the same carbs. The bowl looks pretty clean(a lot cleaner than mine). Depending on what you're going to do with them you may want to order a few jets too...a 40 slow and 100/105/110 mains cover most of the applications.
Kenzo
H-Town, Tejas
>1976 CB550F SuperSport (Work In Progress)
MotoGP Werks Exhaust, Uni Pods
>2006 KTM EXC 453 (EXC 400 w/ Short Stroke Big Bore Kit)
« Reply #7 on: March 12, 2016, 03:24:44 PM »
Double thanks to you Gide, I just ordered the float bowl gaskets from mybigcommerce and added a repair it for good measure so that should sort out any carburation problems. Looking forward to seeing (hearing, feeling?) the result.
« Reply #8 on: March 13, 2016, 03:48:51 AM »
Sorry about that spelling qside, bloody auto spell correct and I didn't notice until later.
