SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Ideas to support exhaust pipes?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Ideas to support exhaust pipes? (Read 1373 times)
75 super sport
Hot Shot
on:
March 19, 2016, 12:30:48 PM »
I am looking for opinions to attatch my 4 into 4 exhaust to my frame because I am scratching my head with this one. Any constructive ideas are appreciated. I will attach a couple photos. Thanks
Logged
"Smoke em if ya got em"
Desert-SOHC
Expert
It's old
Re: Ideas to support exhaust pipes?
Reply #1 on:
March 19, 2016, 12:36:35 PM »
Since there wrapped anyhow.....weld studs to the frame sides of the pipes, fab a bracket similar to the factory one and bolt to the factory position.
Logged
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
754
Really Old Timer ...
Reply #2 on:
March 19, 2016, 08:33:40 PM »
Does that brake pedal have enough room to function ?
An old body shop trick get them plated can opener stir sticks and make pipe brackets out of them...
Logged
Kelowna B.C. Canada
75 super sport
Hot Shot
Reply #3 on:
March 19, 2016, 10:30:30 PM »
It does, it was close though!
Logged
Don R
My Sandcast is a
Saver of unloved motorcycles.
Reply #4 on:
March 20, 2016, 12:05:03 AM »
I've used a T bolt clamp on the pipe and made a strap to put the threaded end of the t bolt through.
Logged
75 super sport
Hot Shot
Reply #5 on:
March 20, 2016, 12:46:14 PM »
Do you have any pictures?
Logged
evanphi
Apparently I'm an
Old Timer
Rhonda the Basket Case
Reply #6 on:
March 21, 2016, 06:32:15 AM »
This is a t-bolt clamp:
When you tighten it there will be some more threaded bit left over. Weld/clamp some metal strapping from your frame with a hole in the end of it to line up with this extra threaded bit. Pop it through the hole, and put another nut and washer on the other side. Boom. Bracketed!
Logged
--Evan
1975 CB750K "Rhonda"
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
