Author Topic: what lengths for double front brake lines?  (Read 1075 times)
Offline riffman12
« on: March 22, 2016, 03:34:02 PM »
So I've decided to run a double banjo bolt at the master cylinder of my '76 750F and run 2 lines down (1 to each caliper) instead of using the factory splitter.
Does anyone know somewhere that sells the lines to do this? Or at least know what lengths I would need for each side?
Bike is a '76 CB750F
Front end and brakes are from a '77 750F
Handlebars are Emgo clubmans
This is not my bike or picture, but same idea:
Thanks a lot
Re: what lengths for double front brake lines?
« Reply #1 on: March 23, 2016, 06:43:16 AM »
https://slingshot-cycles.com/  has or will make what you need.
Shaun is a member here on the forum (pampadori)
measure with a section of any thick wire you have on hand.
Offline riffman12
« Reply #2 on: March 23, 2016, 08:58:51 AM »
hmm I did email slingshot but never heard back. Maybe I'll try again.
I was thinking of just ordering some goodridge lines off of bikebandit:
http://www.bikebandit.com/aftermarket-parts/motorcycle-control-and-brake/brake-lines-fittings-universal/goodridge-universal-dot-brake-line
When measuring, I want the front wheel to be off the ground for full fork extension, right? Any idea of how much slack I need? Or best way to route them?
« Reply #3 on: March 23, 2016, 09:58:44 AM »
Yeah, email him again.  He was on a thread about his brake lines within th epast week, so I know he's around.
Routing? Well thats up to you and how you want your bike to look.  I measured mine with a decent curve, and with my front tire on the ground.
I did the same (2 lines from the MC) setup as you plan on doing.
Offline riffman12
« Reply #4 on: March 23, 2016, 03:20:51 PM »
OK thanks will do.
Do you make the left side line longer than the right side as it's a bit further than the MC?
