you need orginal/or perfekt made alternatives made spacers.
.they have fit total perfekt..in less then 0,1 mm.tolerance.to small the bearings burns up..to big(long) there be slock in the bearing set up..it nees some air/slock..but it are under 0,5 mm...teighten up the vheel must not make the Wheel turn hard
i had used some chims to get the Wheel rotate free.
.think the" retainer "have been kompressed over years..so a thin chim made more Space between the bearings
