Author Topic: I need help identifying and locating a replacement speedometer gear dust seal  (Read 870 times)
Offline craigermags
Guys,
Help me out if you can. I am rebuilding the front wheel hub of my 1971 K1. Part of this rebuild was to inspect the speedometer gear, which I thought needed a good cleaning. I pulled the dust seal off, cleaned in up and repacked the gear.
I am now trying to find a replacement dust seal. The one I pulled off has the marks of TC 34 48 7. I cant seem to located a replacement seal for this.
Any thoughts on who I can contact. I would think any bearing supply store might carry it but I thought if I could just buy it on line I would.
Finally, if anyone has the actual part number for this it might help my search as well.
Thanks all
Craig
Offline Kickstart
I would take it to your local bearing shop and have them order you one, just to be sure you got the correct one.
CycleRanger mentioned on another thread that's it's a double lip seal:
http://forums.sohc4.net/index.php/topic,149089.msg1700742.html#msg1700742
So, this seal is probably what you want, if you just want to order something:
https://www.metricsealsinc.com/store/BASL_OIL_SEAL/i_0_0_159/_S%2034%20X%2048%20X%207%20BASL.aspx
- Chris
75' CB750F Orange flake (rider)
75' CB750F Blue (Project)
75' CB750F Painted black (Project)
No Reserve Racing #171 AHRMA
Offline 333
  • Time for change
P/N is; 91256-056-651, and the description is "OIL SEAL (4.8X14.5X4)". If I believe the site, HondaParts-Direct.com has it for $2.80.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Kickstart
I believe craigermags is asking about the larger seal... and I think the one you're talking about is the seal to the output shaft.
- Chris
Offline 333
  • Time for change
If he took that housing apart, he is out of luck as far as a part number goes.  That assy is not supposed to be taken apart, and there is no part number breakdown.
Offline craigermags
Kickstart, thanks for the lead on the metric seal, this is the one I was looking for. You too Cycleranger!
So great to find guys in the know and with the quick resources to help out
