Author Topic: Crankcase pressure  (Read 579 times)
Offline Ravie
  • Definitely not a
  • Soul to Soul
Crankcase pressure
« on: April 08, 2016, 03:44:39 PM »
The pressure in the oil side of my crankcase is rather high. When I ride the bike it builds up quite a bit of pressure in the oiling system - so much so that it will push a bit of oil past the cap. If I open it directly after I've ridden it sounds like I'm opening a fresh pop bottle!
Keep in mind, if this makes any difference, that I now have 38 actual road miles on the bike, so it's certainly not fully broken in yet. Is this an issue of the rings are just not seated and the firing pressure is building up on the oil side of the pistons?
1975 CB750K5 Rebuild in progress.
http://forums.sohc4.net/index.php?topic=139072.0
Offline CB650CPastor
Re: Crankcase pressure
« Reply #1 on: April 08, 2016, 08:06:51 PM »
How is the crankcase vented? There should never be that kind of pressure.
Tim
Current:1980 Honda CB650C Custom, 1969 Toyota Corona Deluxe Sedan
Past: '07 Honda Rebel 250, '80 Yamaha XS1100 Special, '69 Honda CB160, '67 K15 Suzuki Hillbilly, 1971 VW Super Beetle...
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: April 09, 2016, 05:25:38 AM »
Since you have a 750 I'm assuming that you mean your oil tank is becoming pressurized - this wouldn't be a problem with crankcase pressure since the oil tank is vented seperately.
Make sure the vent line on the back of the oil tank is not plugged (the larger, upper spigot).  The smaller, lower spigot should be connected to the return nipple at the rear of the motor.
mystic_1
- John Augustus Shedd
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #3 on: April 09, 2016, 07:41:50 AM »
mystic_1
I have to actually confirm but...I think I may have this connected backwards. That would explain some #$%*!  lol!
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #4 on: April 09, 2016, 08:13:39 AM »
Oh man, Mystic. You're the fecking king. I had the upper breather connected to the damn valve cover spigot. Thanks a bunch!
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: April 09, 2016, 09:23:31 AM »
Oh yeah, that would do it :D
Both of those lines should just be vented to atmo, down in front of the swingarm pivot.
mystic_1
« Last Edit: April 09, 2016, 09:25:29 AM by mystic_1 »
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #6 on: April 09, 2016, 09:25:36 AM »
Yep. I don't blame the PO for pushing me in that direction...because it's their fault I connected it wrong...they had it that way to begin with!  I simply disconnected the valve cover hose and stuck it down next the the oil lines and made a new vent hose for the top oil tank vent. No problemo.
