Author Topic: Trouble After Tank Lining  (Read 1835 times)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« on: April 21, 2016, 03:52:53 PM »
Well, ever since I tore my bike down for it's spring tune up and a redkote tank seal.  I think I may have sealed something I shouldn't have.  :-[
Bike wants to starve for fuel and the simple remedy is to crack the gas cap open.
I already soaked the cap in MEK to clean the redkote off of that.  And peeled back the liner from around the big hole.  Ran a pick down the little hole (which I assume is a rain drain?) and still!  she wants to stall out on me.  Didn't behave this way before the tank seal.  unless I actually ran her out of gas completely  ;D
Before ya'll ask, I gave the tank 5 days to cure at 70degree temps before putting any gas in it.  I read the warning on the can about excess liner and cure times and off-gassing.  I'm fairly confident I did a little too good of a job!  At first I suspected those damn daichi condensers were going out.  But running with the cap open brought her back to life.
Is there anything inside that tank that shouldn't have been red-kote'd?
Offline Gordon
  • 750K1, 550K2
Re: Trouble After Tank Lining
« Reply #1 on: April 21, 2016, 04:02:22 PM »
Even though you soaked the cap in MEK, it sounds like you still didn't clear out the vent hole.
  • Holy Cow! I'm a
« Reply #2 on: April 21, 2016, 04:07:14 PM »
Does the 550 supersport cap have a vent hole?  I can see daylight thru the tab where the chain connects and the spring loaded ears have big holes that are clean all around.  Is there anything else I should look for?
Offline jonda500
« Reply #3 on: April 21, 2016, 06:03:07 PM »
They also have a tiny triangular hole in the top - it's hard to see cause it's so small!
John
A starter clutch thread:
  • Holy Cow! I'm a
« Reply #4 on: April 21, 2016, 08:15:12 PM »
Tiny triangle hole, I'll get my magnifiying glass out and see if I can poke it then!!
  • Holy Cow! I'm a
« Reply #5 on: April 23, 2016, 10:53:36 PM »
Follow up question, by triangle, did you mean the ridge off the side of the cap's center?  That toblerone chocolate shaped bump?
Offline jonda500
« Reply #6 on: April 24, 2016, 12:49:53 AM »
I just looked at my spare ss fuel cap and found it has like you say just a little ridge that the handle sits on when folded down, whereas the one on my bike has a teeny triangle hole on the side of the centre raised bit...
Dunno how the no hole one breaths  ???
John
  • Holy Cow! I'm a
« Reply #7 on: April 25, 2016, 11:35:52 AM »
Well fellas, I made a solution.  With the smallest drill bit I have.  That oughta keep me rollin.
Offline Powderman
« Reply #8 on: April 25, 2016, 09:17:42 PM »
How did you get Redkote in the cap?
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #9 on: April 26, 2016, 02:48:29 PM »
yeah that was my question too. When doing tank liners, you should completely remove and put away the nice chrome cap entirely, as well as the petcocks...use rubber bung/plugs for the petcock hole(s) and plumber's sewer test plug or similar "mechanical" plug for the filler neck. like this:
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
  • Holy Cow! I'm a
« Reply #10 on: April 26, 2016, 04:11:48 PM »
Simple answer is I didn't have one of them fancy stoppers to plug the big hole.  Run whatchabrung
Offline Powderman
« Reply #11 on: April 26, 2016, 09:51:51 PM »
Saran wrap, zip lock bag, balloon, aluminum foil, anything you can put over the opening with a rubber band. Buy a new cap.
  • Holy Cow! I'm a
« Reply #12 on: April 27, 2016, 02:59:02 PM »
I'll look into replacing the cap eventually.
Making more problems for myself is my specialty
