Author Topic: Plug reading  (Read 1666 times)
Offline 550Resto
Plug reading
« on: April 23, 2016, 11:47:47 AM »
Hey all, not 100% on reading plugs and was hoping someone could she some light on it for me. I've attached a picture of the number 1 cylinder plug. 78 550k, delkevic 4into1 exhaust, stock airbox. Thanks!
Offline CB650CPastor
Re: Plug reading
« Reply #1 on: April 23, 2016, 02:14:34 PM »
Was this a plug chop? Looks pretty lean unless the picture is washed out from a flash. I don't see any color on the insulator at all. Insulator should be brownish/tan. Take a picture in good light without the flash.
Tim
Current:1980 Honda CB650C Custom, 1969 Toyota Corona Deluxe Sedan
Past: '07 Honda Rebel 250, '80 Yamaha XS1100 Special, '69 Honda CB160, '67 K15 Suzuki Hillbilly, 1971 VW Super Beetle...
Offline 550Resto
Re: Plug reading
« Reply #2 on: April 23, 2016, 04:04:29 PM »
No plug chop. Here are 2 without flash. What are the consequences of running too lean or too rich?
Offline mrfish2
  • I might be a
Re: Plug reading
« Reply #3 on: April 23, 2016, 06:12:57 PM »
Too lean will overheat the engine, causing it to ping. Too rich burns a lot more gas and causes stumbling. Have you read through the Carb FAQ?
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Re: Plug reading
« Reply #4 on: April 23, 2016, 06:38:25 PM »
plug readings mean nothing unless they are for ONE, constant throttle position, and you didnt list anything.
we cant help unless you do a proper chop and list the throttle position.
Offline brewsky
Re: Plug reading
« Reply #5 on: April 24, 2016, 07:39:42 AM »
What gap are you using?
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Re: Plug reading
« Reply #6 on: April 24, 2016, 07:41:01 AM »
good catch  :o
Re: Plug reading
« Reply #7 on: April 24, 2016, 07:44:47 AM »
A little rich won't be bad but too lean is not good.When you check the plug color make sure to look down deep into the center porcelain to see some color,even w/ sunlight shining directly into it.What main jet are you running now ?
Offline 550Resto
Re: Plug reading
« Reply #8 on: April 24, 2016, 08:19:21 AM »
Spark plug gap is per the manual, between .02 and .03 inches. Mains are stock. It had 100 mains in it, but harisuluv swapped them out to stock size...92 or 90 I believe.
Offline brewsky
Re: Plug reading
« Reply #9 on: April 24, 2016, 08:33:16 AM »
If so, my eyes are really BAD!
.02 mm maybe?
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Re: Plug reading
« Reply #10 on: April 24, 2016, 09:11:58 AM »
.02 mm maybe?
.028in. would be ok
Re: Plug reading
« Reply #11 on: April 24, 2016, 09:13:09 AM »
the picture above shows what looks like noticeably small plug gap on one plug :o
the other photo is too blurry to tell
« Last Edit: April 24, 2016, 09:14:48 AM by flybox1 »
Offline 550Resto
Re: Plug reading
« Reply #12 on: April 24, 2016, 09:14:19 AM »
Manual calls out 06-07mm  or .024-.028 inches. I set them all at .026 inches with a plug gapper.
Offline 550Resto
Re: Plug reading
« Reply #13 on: April 24, 2016, 09:15:14 AM »
Yeah somehow the gap on that one was way smaller even though I had set them all the same. Re gapped it.
Re: Plug reading
« Reply #14 on: April 24, 2016, 09:15:51 AM »
Definitely a problem  ::)
Offline 550Resto
Re: Plug reading
« Reply #15 on: April 24, 2016, 09:29:43 AM »
If running too lean how does one richen the mix? I have searched the forums some and I've read that there are adjustment screws on the side of the carbs, but I'm not seeing any. All I see are the IMS on the bottom of the carbs. These are pd46c carbs. Most stuff I see is in regards to the 46a's
Re: Plug reading
« Reply #16 on: April 24, 2016, 09:35:38 AM »
do you know what the IMS does?
Offline 550Resto
Re: Plug reading
« Reply #17 on: April 24, 2016, 11:10:44 AM »
From what I've read the idle mixture screws can control either air or fuel depending on the model of carbs. Not sure about the 78 style carbs, but I imagine it would control fuel. If that's the case turning clockwise would richen and counter would lean it out, correct?
Offline jonda500
Re: Plug reading
« Reply #18 on: April 24, 2016, 04:47:53 PM »
No, that would be the older air screws. Your IMS's will make it leaner by screwing them in, richer by screwing them out,
John
A starter clutch thread:
