Author Topic: Cleaning the Engine - hot or cold?  (Read 3395 times)
« on: November 15, 2006, 01:06:52 PM »
I have to clean the oil leak on my K4 engine, and after a little research have a few questions.
1. It seems that its recommended to clean a COLD engine and not a hot one - anyone know why?
2.  Is there any cleaning difference between GUNK and Simple Green (never used it but Ive used GUNK before).
3. Any other tips for getting rid of the oil residue between the fins?
thanks
Andy
Offline dusterdude
Re: Cleaning the Engine - hot or cold?
« Reply #1 on: November 15, 2006, 01:54:36 PM »
the only reason i know of between hot or cold is,the cold water on a hot engine could possibly make the engine cases or something else on the motor crack.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
johnny-from-bel
« Reply #2 on: November 15, 2006, 02:32:59 PM »
Correct. It is called thermo shock. Use hot water if you decide to clean the engine while warm.
« Reply #3 on: November 15, 2006, 02:34:59 PM »
Mmmm but what about when its raining?? Wouldnt cold rain crack hot motors according to this logic?  ;)
Thanks for the replies,
Andy
Offline paxtonpony
  • Up the Irons!
    • My Pics
« Reply #4 on: November 15, 2006, 02:47:08 PM »
Rain and standing water tends to have a temperate very close to the air temperature.  Since the metal is already in contact with the air, and therefore that temperature, there is not a large variance.  However, if it's a warm day and you have a very warm or hot engine, there will be a large difference in temperature from very cold hose water.  That's when you have your problems and can develop stress fractures.
Good question though, most people don't know.
1969 CB750K - Wrecked
1978 CB750K - Sold
1992 GS500 Streetfighter - Sold
1975 CB750F - Sold (sniff, sniff)
1994 VFR750F - Sold
1990 GSXR 750 - Sold
1999 CBR1100XX - Sold
2000 Triumph Legend TT - Bike of the week for me?
1992 Mustang - Paxton powered (12.02@115mph on street tires) and For Sal
Offline SD750F
    • My Business Site
« Reply #5 on: November 15, 2006, 02:49:34 PM »
Rain cracking engine, well not really. It has to do with thermal capacity. Water is an excellent retainer of thermo energy (insulator) that is why water will hold heat for a long time, or cold for that mater. Also is has good thermo conductance. Okay so really the volume of the water is direcly propotional to it's capacity. Spraying large volumes of water such out of a hose will wick away much more heat than small individual rain drops. Even if the rain is coming down hard. But if you would drive through a large puddle of water, that would be the same as spaying with a hose. But in that case wouldn't you have "other" problems like hydroplaning???
I tried to make this physics problem straight forward. But I could provide the thermal capacities of water calculations if anyone is interested...
« Reply #6 on: November 15, 2006, 04:02:21 PM »
Ok so its beginning to make more sense now -thanks for the very informative replies -SD750F if you were serious about those thermal calculations then yes Id be interested in learning some more. Particulary about how the surface area of the water versus its thermal capacity can lead to such a dramatic result such as cracking the engine....and I realise its about thermal conductivity and metal fatigue. More physics please  8)
Thanks,
Andy
Offline kghost
« Reply #7 on: November 15, 2006, 04:06:41 PM »
I like simply green....
Use it undiluted to get the really heavy stuff off...let it sit a bit
Be sure to rinse completely...leaving it on will foster corrosion of aluminium.
Stranger in a strange land
Offline Nate
    • Alternative Cruisers BB
« Reply #8 on: November 15, 2006, 04:21:13 PM »
I have a Simple Green knockoff sold by Costco, just called all purpose cleaner.  I just tried it on a part the other day and it seems to work even better than simple green, not to mention it's cheaper and is only sold by the gallon.
Offline mcpuffett
« Reply #9 on: November 16, 2006, 02:16:48 AM »
spray carb cleaner is good for those awkward areas  ;),   mick.
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #10 on: November 16, 2006, 02:20:11 AM »
Gunk is old-fashioned and nasty stuff.
Don't let it drip off your engine onto tarmac as it disolves the binding agent. (don't ask...)
It's also very nasty when washed into the water course.
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
« Reply #11 on: November 16, 2006, 03:06:01 AM »
I had 4 gallons of stale gas so I mixed it 50/50 with diesel and sprayed some of it on my warm engine, and it cleaned the gunge off really well. I've heard "Simple Green" is very good, but I've never used it. Cheers, Terry.
« Reply #12 on: November 16, 2006, 05:27:23 AM »
Thanks all - great info as usual. Much appreciated.
cheers
Andy
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #13 on: November 16, 2006, 09:40:37 AM »
I know they use DAWN dish detergent to remove oil from wildlife after a spill...
I have seen it used after a semi oil tanker crash to clean the road..
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Offline kghost
« Reply #14 on: November 16, 2006, 04:46:34 PM »
I use tide laundry detergent to was my floors and even my hands....suppose that would work too in a water mix.
Tide and gas....mmmm might set off the TSA.... :D
Offline jabbadeznuts
« Reply #15 on: November 21, 2006, 10:57:59 AM »
I spray on the cleaner with the engine hot, hoping that the grime will be a little looser. I then wait for the engine to cool 'till it's warm to the touch. Spray it down and attack with a tooth brush for the hard/extra dirty spots.
'75 CB550
'82 Suzuki GN125 - glad to be rid of that thing.
