Author Topic: CB750 AHRMA Sportsman 750 Racer  (Read 196946 times)
Offline slikwilli420
  • Master of Disaster
Re: CB750 AHRMA Sportsman 750 Racer - shipping my crank?
« Reply #175 on: February 05, 2017, 01:43:03 PM »
Got the cases split today and pulled the crank, marked the bearing halves, pulled the rods and started cleaning.
Going to build a box to ship the crank and Cycle X rods off to Cycle X for lightening, balancing and rod install this week.
Regarding bearings, does everyone generally replace all of them? Is there a source for a whole set? CMSNL has them piecemeal but was hoping for the set.
Once the crank comes back the trans will go out and that pretty much does it for the bottom end.
Re: CB750 AHRMA Sportsman 750 Racer - trans bearing sources?
« Reply #176 on: February 05, 2017, 02:14:55 PM »
Cant sell as a set, because there are many different combinations..
« Reply #177 on: February 05, 2017, 06:37:36 PM »
CB750 main and con bearings are available in the USA no problem.
« Reply #178 on: February 05, 2017, 08:07:18 PM »
Looking for the roller bearings for the trans, not the crank/ rod bearings.
Offline Haybus
« Reply #179 on: February 05, 2017, 08:14:48 PM »
I just got an email from CycleX about trans bearings. I would call them.
Alan
« Last Edit: February 05, 2017, 08:16:52 PM by Haybus »
75 CB750
76 KZ900
« Reply #180 on: February 06, 2017, 07:52:40 AM »
I will get with Cycle X and see what they have. I need to order some other bottom end goodies anyway. I did find a fantastic article on replacing the trans bearings in a '76F which should be the exact same as my '77 engine, but I will make sure to use part numbers from '77 just in case. Here is the article:
https://wrenchandspanner.wordpress.com/2014/12/16/cb750f-transmission-bearings/
It seems like a simple enough process and that will give solid piece of mind when this thing is humming along at 10 grand.
Re: CB750 AHRMA Sportsman 750 Racer - what to replace in the bottom end??
« Reply #181 on: February 08, 2017, 10:41:06 AM »
Well the crank has been separated from its home and is packed (very well I might add) and off to Cycle X to be lightened/balanced and have the Cycle X rods installed.
As I dig deeper into the lower end, what do I need to replace and what is just a nice-to-have?
I am definitely planning on the following:
- total oil pump rebuild
- oil seals throughout
- primary chains
- primary chain tensioner
- undercut trans
Things that I don't know if they are necessary:
- lower end roller bearings - how do I tell if these are still good aside from spinning and listening
- drive rubbers behind the clutch
Anything else that falls into either category that I am forgetting?
« Last Edit: July 10, 2017, 01:10:01 PM by slikwilli420 »
« Reply #182 on: February 08, 2017, 12:44:06 PM »
HayZuez..that is a box... Bombproof.... A bit bigger than i would have built.
 Takes the worry out of sending it away.
 I usually listen/feel the bearing while slowly turning it...look for roughness or irregular feel.
And sideplay..no excessive play. And no corrossion.
Offline bear
  • Leeton in Australia
« Reply #183 on: February 08, 2017, 02:35:04 PM »
In my opinion cush drive rubbers should always be replaced in a competition motor.
Brian
« Reply #184 on: February 08, 2017, 02:53:36 PM »
Brian
With the better rubbers now on offer too.... ;)
« Reply #185 on: February 08, 2017, 03:37:01 PM »
Any sources besides Cycle x?
Brian
« Reply #186 on: February 08, 2017, 04:48:44 PM »
Brian
I'm pretty sure Brian gets his rubber dampers here I Australia, I'm sure he'll chime in soon. There is also someone who sells a complete kit for the dampers, maybe in Germany, if I can find the link i'll post it here... ;)
I was wrong, French, not german... ;)
http://forums.sohc4.net/index.php?topic=119730.0
http://honda60-70s.net/Pieces/23110-300-030_GB/23110-300-030_gb.html
Offline Old Scrambler
« Reply #187 on: February 08, 2017, 06:16:03 PM »
If your motor has the auto drive-chain oiler, I would remove the little tin tray to delete the oil-feed. Although the K7 was an upgrade, others on this site report the K8 shifter-drum is the BEST. I assume you already have the white tensioner components for the primary and cam chains..............and then there is the consideration for stronger gear-dogs for top-gear.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #188 on: February 08, 2017, 06:27:19 PM »
I will definitely be upgrading all the tensioner wheels for primary and cam. When you say stronger gear dogs do you mean undercut or replacement? Definitely getting the gears undercut.
« Reply #189 on: February 08, 2017, 06:27:39 PM »
Brian
A French fella Mick. ;)
« Reply #190 on: February 08, 2017, 06:56:47 PM »
Brian
Yep, got that Mike.... ;)
« Reply #191 on: February 18, 2017, 04:08:11 PM »
Here's the scoop gents. I have made peace with the fact that I cannot afford to finish the motor and the bike ahead of my June deadline. I decided to pick up a good street motor do now I can focus on finishing the other aspects of the bike as well as have the cash to buy riding gear and pay for the race class and entry fees.
Question is what should be done to this street motor before it hits the track? I am planning on a full oil pump seal/spring kit and am pondering a cam chain but won't be splitting the cases. Thoughts on a riveted chain?
Anything else?
« Reply #192 on: February 18, 2017, 05:05:02 PM »
Assuming its a K6 or earlier and you will have a few days of admiring the motor while on your bench before you insert it into the chassis................Cam-chain & tensioner kit; F2 or 41A cam; clean up the casting debri and the intake ports; do the oil-pump mostly for peace of mind; remove the anchor on the left end of the crank & shrink the cover (cut the tail off of the crank); maybe remove the electric-starter gear and motor; get 2 or more L-I batteries (1 for backup) and go total-loss ignition; use the best (high-tensil) drive chain; have a spare clutch-pack; tune and race ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #193 on: February 18, 2017, 06:44:10 PM »
If it's a relatively low mileage, stock motor in good condition, I wouldn't do anything more than a good tune-up. ;)
« Reply #194 on: February 19, 2017, 08:43:16 AM »
Old scrambler , I thought about most of that although am not going to pull the head since it was just assembled.
I hear the 41a really comes alive at higher rpms and would be a good addition do I'm thinking on that one.
All of the charging/starting bits are going away once I get the motor installed and running.
Cam I do a cam chain and rivet the link so I don't need to pull the engine down? At this point that's the only real option for this motor.
« Last Edit: February 22, 2017, 07:46:22 PM by slikwilli420 »
« Reply #195 on: February 19, 2017, 04:03:24 PM »
I have to make the correct length camchains for mine. People suck in their breath but it's fine as long as you do a good job on a true rivot link, not a press type. Tsubaki don't offer anymore but check for DID and whatever CycleX is offering.
Offline turboguzzi
« Reply #196 on: February 20, 2017, 12:10:23 AM »
+1, make sure you have a nice, weighty dolly to hammer the pin against
« Reply #197 on: February 24, 2017, 07:44:21 AM »
Good thoughts on the cam chain gents. I will talk to Cycle X and see what they can offer. This was a sub-20K mile engine so I may throw caution to the wind since it won't have a high lift cam or stronger springs, but we'll see.
Nothing too outrageous going on other than getting the roller off the bench and on the floor in place of my Vintage Speed Part project, which has been relegated to the back burner for now. Days are coming and going fast on this one.
I have take a number of trail measurements with my 45mm offset trees and with the forks where I think they will be once complete, I am in the 95mm area for trail. I will double and triple check these figures again before I commit to triple trees, but I am close.
I have also filled out the swingarm geometry form from Race Tech for the shocks so that order will be going in soon, along with a spring/emulator kit for the GL forks.
Ideas are flowing for a simple and light seat mount so that will be buttoned up soon as well.
Rearset bracket designs are at the water jet shop now. I am using the approach Haybus used on his racer, with welded tabs on the frame and an aluminum bracket that sandwiches between those to hold the peg assemblies. Should be easy to repair in the event that the rubber side goes up so that will be nice.
« Last Edit: July 10, 2017, 01:11:37 PM by slikwilli420 »
« Reply #198 on: February 24, 2017, 09:22:08 AM »
Just use chain peening tool.
Re: CB750 AHRMA Sportsman 750 Racer - caliper to spoke clearance?
« Reply #199 on: February 28, 2017, 04:49:46 PM »
So I talked to Ken at cycle x today and laid out my intentions and he didn't think a new cam chain on a stock motor was necessary so I'll probably just do a cam and sprocket and call it good.
Regarding caliper to spoke clearance, I have about 1/8"at this point. Is that enough or should I design a little more spread into the triple trees?
