Author Topic: Why does PAMCO Ignition still work without it being grounded? CB750  (Read 681 times)
Offline andyvclifford
Hey all,
this might be a stupid question but im going to ask it anyways.  I installed a PAMCO ignition on my 75 CB750 a few weeks ago.  At one point i realized the ground (BLACK) wire which should be grounded to the case somewhere had come undone from where I had it not making any connection.  However, the bike starts up and fires plugs just fine.  Does this indicate that I did something else wrong with the wiring or would this be the case no matter what?
Thanks
Andy
Online Don R
Re: Why does PAMCO Ignition still work without it being grounded? CB750
« Reply #1 on: July 09, 2016, 01:28:08 PM »
 It may be getting a good enough ground from the engine case but I wouldn't count on it staying that way.
« Reply #2 on: July 09, 2016, 01:35:09 PM »
So the unit itself is actually grounded in the way the old ignition points is?
Offline Scott S
« Reply #3 on: July 09, 2016, 01:40:17 PM »
 Pete always called that an "incidental ground". It's probably grounding itself out somewhere just by touching the case/frame/engine/whatever. But don't rely on that. Give it a proper ground.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #4 on: July 09, 2016, 02:00:51 PM »
Gotcha!  Thank you - just been having a host of problems with the bike running poorly and wanted to root this out in a seperate thread.
