SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
High Performance and Racing Forum
(Moderators:
Sam Green Racing
mlinder
Topic:
Webers for sale,less manifold cheap.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Webers for sale,less manifold cheap. (Read 1645 times)
754
Really Old Timer ...
on:
July 30, 2016, 11:56:34 AM »
Ebay #152171363842 ........250 bux with wrong manifold.
Say DCOM..we use DCOE 40 series look like the same. Ask them what venturi size .
One diff I see the fuel inlet is not drilled down from the top , but rather the side.
Having touble expanding. Pic to read the series number..you want 40, not 45..
Last Edit: July 30, 2016, 05:26:39 PM by 754
Logged
Kelowna B.C. Canada
754
Re: Webers for sale,less manifold cheap.
Reply #1 on:
July 30, 2016, 05:28:16 PM »
Do some reading before you buy, there is differences...and ask seller what it says on the series boss, and venturi size..
Logged
Kelowna B.C. Canada
scottly
Global Moderator
Humboldt, AZ
Reply #2 on:
July 31, 2016, 05:37:55 PM »
I thought the DCOM was a typo, but there really is such a thing! They use a diaphragm accelerator pump, instead of the piston in the DCOE. They also have vacuum ports for ignition advance. Never seen plastic stacks on a Weber before, either!
Logged
754
Reply #3 on:
July 31, 2016, 05:41:55 PM »
Apparently. The stacks do not interchange. With DCOE
Venturi holder might be different, a lot of stuff fits though..
I did note he said or offer, so they are reasonable. If they are 40,s.... Bet they are not from Italy though.
Logged
Kelowna B.C. Canada
scottly
Global Moderator
Humboldt, AZ
Reply #4 on:
July 31, 2016, 06:05:23 PM »
It looked like I could almost make out 40 on one of them, and the seller does state that they are 40's, but I doubt he's an expert; the aux look like they are in backwards, as you can see the alignment pin.
Very doubtful they are Italian, more likely Spanish.
Logged
Tintop
Old Timer
Reply #5 on:
July 31, 2016, 06:23:23 PM »
Very likely 40's, as they were used on early Alfa's. The accel pump is same(?), or similar to the IDA. Pretty sure they use the same chokes & and venturis as the DCOE's.
Logged
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
754
Reply #6 on:
July 31, 2016, 06:39:22 PM »
If you want to make your own manifold that flange cutoff is a good start.
Logged
Kelowna B.C. Canada
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
(Moderators:
Sam Green Racing
mlinder
Topic:
