Author Topic: Webers for sale,less manifold cheap.  (Read 1676 times)
« on: July 30, 2016, 11:56:34 AM »
Ebay #152171363842 ........250 bux with wrong manifold.
Say DCOM..we use DCOE 40 series look like the same. Ask them what venturi size .
One diff I see the fuel inlet is not drilled down from the top , but rather the side.
Having touble expanding. Pic to read the series number..you want 40, not 45..
« Last Edit: July 30, 2016, 05:26:39 PM by 754 »
Re: Webers for sale,less manifold cheap.
« Reply #1 on: July 30, 2016, 05:28:16 PM »
Do some reading before you buy, there is differences...and ask seller what it says on the series boss, and venturi size..
« Reply #2 on: July 31, 2016, 05:37:55 PM »
I thought the DCOM was a typo, but there really is such a thing! They use a diaphragm accelerator pump, instead of the piston in the DCOE. They also have vacuum ports for ignition advance. Never seen plastic stacks on a Weber before, either!
« Reply #3 on: July 31, 2016, 05:41:55 PM »
Apparently. The stacks do not interchange. With DCOE
 Venturi holder might be different,  a lot of stuff fits though..
 I did note he said or offer, so they are reasonable. If they are 40,s.... Bet they are not from Italy though.
« Reply #4 on: July 31, 2016, 06:05:23 PM »
It looked like I could almost make out 40 on one of them, and the seller does state that they are 40's, but I doubt he's an expert; the aux look like they are in backwards, as you can see the alignment pin. ;) Very doubtful they are Italian, more likely Spanish.
Offline Tintop
« Reply #5 on: July 31, 2016, 06:23:23 PM »
Very likely 40's, as they were used on early Alfa's.  The accel pump is same(?), or similar to the IDA.  Pretty sure they use the same chokes & and venturis as the DCOE's.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #6 on: July 31, 2016, 06:39:22 PM »
If you want to make your own manifold that flange cutoff is a good start.
