Author Topic: Show me your steering dampers!  (Read 35510 times)
Offline Swoop
Re: Show me your steering dampers!
« Reply #150 on: May 28, 2016, 10:41:04 AM »
Why not tone things down and start a gun control thread?
Lighten up....he only asked how to mount the damn thing!
Now that would be fun!
You are THE Fun ghi (sp?)  ;D
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #151 on: May 28, 2016, 12:27:52 PM »
Offline cb650PK
« Reply #152 on: May 28, 2016, 03:36:59 PM »
No difference between gun control and steering damper........just use both hands either case!
Take both hands off the bars at 45mph on decel and see!
Nonsense, both should work fine two handed or one handed. Haven't figured out the no hands thing with gun yet;)
S CB750 na vecne casy a nikdy jinak.
« Reply #153 on: May 28, 2016, 05:43:32 PM »
I think he's just saying you're a fun guy Jimmy, which is nice, he just wasn't sure about the spelling. (he's probably foreign) ;D
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #154 on: May 28, 2016, 06:49:26 PM »
 :). Thanks Terry
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #155 on: May 28, 2016, 06:57:22 PM »
I was thinking he was going for the Canadian male name Guy, which sounds like Gee. But I'm probably wrong.
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #156 on: May 29, 2016, 09:42:33 AM »
Or maybe he meant Jimmy was a fungus? Seems an odd description...
Probably a fungi.
Offline mystic_1
  • 1970 CB750K
« Reply #157 on: May 29, 2016, 11:47:00 AM »
Possibly also a clarified butter, or a karate uniform.
In damper news, mine arrived, but I'm in no rush to install it, so I'm taking the time to consider all options.  I'm leaning towards installing it on the left, and connecting to a fork leg bracket that's clocked to place the attachment point to the inside of the left fork tube, sort of mimicking the geometry of George's setup.
mystic_1
- John Augustus Shedd
« Reply #158 on: May 29, 2016, 01:57:10 PM »
 He does have moss growing on his garage...... lives on the Wet Coast...
Offline Sgt.Pinback
« Reply #159 on: May 30, 2016, 02:50:58 AM »
Doc, I love a motorcycle!
Offline gschuld
« Reply #160 on: May 30, 2016, 04:56:41 PM »
mystic_1
I spend a considerable amount of time regarding alignment, symmetry of stroke left to right, and maximizing the lock to lock equally from side to side.  My earlier pics show a full left and a full right extension.  If you look close, you will see I am a little less than 1/8" short of the stops on each direction.  My application is a street able road racer, so I intend to shorten the lock to lock anyway.
It uses a later 50mm lower tree that has the big holes and machined the bronze fitting at the tree and the 5/8" steel rod threaded for the damper.  This leaves zero potential for slippage of a bolt on bracket, as it's welded in.  But you need to be very confident regarding the right positioning before committing to weld.
I chose left side for the simple reason that if, for some reason, I want to alter the damper setting while riding, I'd rather have my throttle hand on the grip and use my left for the adjustment.
Seems safer and more natural to me.
George
Offline nobody
« Reply #161 on: August 01, 2016, 08:35:55 AM »
I finally got mine mounted up, thanks for all the pictures and feedback to give me ideas.
74 cb750k
