Yeah, as much as I like the look of your custom top triple clamp Sean, I'm trying to understand why you needed it in the first place?
Same for the racetech cartridge emulators, I've had no issues with the standard damping, (a lot can be achieved with just adding a different weight oil) and while I can always see the positives in being able to fine tune your damping, (I am a gadget nut too) it's not something that I think critical, so really, a 100 dollar set of Progressive springs is about all anyone would need, and they'd need them even if they kept their OEM forks, after 40 years.
Just to add to the mix, I had a very cool S&W air kit for a set of GL1000 forks that I installed at the same time I fitted them, basically to take up any sag and to get that plush "air ride" feel that I enjoyed so much in my 1986 GL1200 Interstate that of course came with air assisted suspension from the factory, and I was surprised last weekend when checking the frame number that after 2 years since I installed them, they're still holding air! Yep, it looks like it's lost a couple of psi since 2014, but that's not bad, at all.
