Author Topic: How to Bathe a Cat  (Read 1352 times)
USN20
How to Bathe a Cat
« on: November 26, 2006, 08:01:06 AM »
                                             How to Bathe a Cat
- Thoroughly clean the toilet.
- Add the required amount of shampoo to the toilet water, and have both lids lifted.
- Obtain the cat and soothe him while you carry him towards the bathroom.
- In one smooth movement, put the cat in the toilet and close both lids. (You may need to stand on the lid so that he cannot escape).
CAUTION: Do not get any part of your body too close to the edge, as his paws will be reaching out for any purchase they can find.
- Flush the toilet three or four times. This provides a "powerwash and rinse" which I have found to be quite effective.
- Have someone open the door to the outside and ensure that there are no people between the toilet and the outside door.
- Stand behind the toilet as far as you can, and quickly lift both lids.
- The now-clean cat will rocket out of the toilet, and run outside where he will dry himself.
        Best regards, The Dog
Offline Rsnip988
Re: How to Bathe a Cat
« Reply #1 on: November 26, 2006, 12:06:11 PM »
I tried that once,    she didnt like it
RKS
R.K.S.
1976 CB750 K6 Full
1976 CB750 K6 Cafe'ish
Offline kghost
« Reply #2 on: November 26, 2006, 12:24:24 PM »
I often think the Moderators here are in a position akin to......
Herding cats....they just get tired and it annoys the cats.
Maybe they should try the swirlly method instead  ;D
Stranger in a strange land
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #3 on: November 26, 2006, 01:45:17 PM »
INSTRUCTIONS FOR GIVING YOUR CAT A PILL
1. Pick cat up and cradle it in the crook of your left arm as if holding a baby. Position right forefinger and thumb on either side of cats mouth and gently apply pressure to cheeks while holding pill in right hand. As cat opens mouth, pop pill into mouth. Allow cat to close mouth and swallow.
2. Retrieve pill from floor and cat from behind sofa. Cradle cat in left arm and repeat process.
3. Retrieve cat from bedroom, and throw soggy pill away. Take new pill from foil wrap, cradle cat in left arm holding rear paws tightly with letf hand. Force jaws open and push pill to back of mouth with right forefinger. Hold mouth shut for a count of 10.
4. Retrieve pill from goldfish bowl and cat from top of wardrobe. Call spouse from garden.
5. Kneel on floor with cat wedged firmly between knees, holding front and rear paws. Ignore low growls emitted by cat. Get spouse to hold cat's head firmly with one hand while forcing wooden ruler into mouth. Drop pill down ruler and rub cat's throat vigorously.
6. Retrieve cat from curtain rail, get another pill from foil wrap. Make note to buy new ruler and repair curtains. Carefully sweep shattered figurines from hearth and set to one side for gluing later.
7. Wrap cat in large towel and get spouse to lie on cat with its head just visible from below spouse's armpit. Put pill in end of drinking straw, force cat's mouth open with pencil and blow down drinking straw.
8. Check label to make sure pill not harmful to humans, drink glass of water to take taste away. Apply band-aid to spouse's forearm and remove blood from carpet with cold water and soap.
9. Retrieve cat from neighbor's shed. Get another pill. Place cat in cupboard and close door onto neck to leave head showing. Force mouth open with dessert spoon. Flick pill down throat with elastic band.
10. Fetch screwdriver from garage and put door back on hinges. Apply cold compress to cheek and check records for date of last tetanus shot. Throw T-shirt away and fetch new one from bedroom.
11. Ring fire brigade to retrieve cat from tree across the road. Apologize to neighbor who crashed into fence while swerving to avoid cat. Take last pill from foil wrap.
12. Tie cat's front paws to rear paws with garden twine and bind tightly to leg of dining table. Find heavy duty pruning gloves from shed. Force cat's mouth open with small spanner. Push pill into mouth followed by large piece of fillet steak. Hold head vertically and pour 1/2 pint of water down throat to wash pill down.
13. Get spouse to drive you to emergency room; sit quietly while doctor stitches fingers and forearm and removes pill remnants from right eye. Stop by furniture shop on way home to order new table.
14. Arrange for vet to make a housecall.
PS. How to give a dog a pill:
Wrap it in bacon.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline Rsnip988
« Reply #4 on: November 26, 2006, 03:08:30 PM »
thats accurate too
rks
R.K.S.
1976 CB750 K6 Full
