Author Topic: 1966 S90 - FRONT END SWAP SUGGESTIONS * PLAN B  (Read 24699 times)
Offline grcamna2
Re: 1966 S90 - FRONT END SWAP SUGGESTIONS
« Reply #50 on: June 27, 2017, 03:30:53 PM »
Do CB350 front drums stop well? I liek the look of the entire front end on those bikes. It look liek I could pick up the entire front end and a front drum hub for not too much.
Would lacing the hub to an 18" wheel be a nightmare? I guess that might involve custom spokes?
The CB350K4 twin & early CB360 front-end and drum wheel will be a nice choice;they do stop very strong and it's an 18" front wheel stock.
« Last Edit: June 27, 2017, 03:50:12 PM by grcamna2 »
75' CB400F/'bunch o' parts'
« Reply #51 on: June 27, 2017, 03:44:14 PM »
You will likely need to install new stops for your forks so they do not smash/smack the beautiful S90 tank.
David
Offline SKTP
« Reply #52 on: June 27, 2017, 04:14:22 PM »
Great news...problem solved...search is on. Since the brake and clutch will both be cable, I am thinking inverted levers with internal cable routing...
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline grcamna2
« Reply #53 on: June 27, 2017, 04:34:16 PM »
That 350/360 front drum wheel is a nice part but heavy-looking for the S90.
Offline SKTP
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline grcamna2
Offline SKTP
« Reply #56 on: June 27, 2017, 06:06:57 PM »
Here's a quick photoshopping of a CB360 drum
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline grcamna2
« Reply #57 on: June 27, 2017, 06:15:14 PM »
The Super 90 was a screamer back in the day even stock! I can just imagine what it's like w/ the 190 engine,you could easily bury the speedo  :) What's the Bore & Stroke work out to ?
Offline SKTP
« Reply #58 on: June 27, 2017, 06:26:22 PM »
From that link:
This 4 valve, 62mm bore x 62mm stroke engine is the newest edition directly from Daytona Motor Co. The new FLX-190 comes stock with an updated close ratio transmission, an AUTO-DECOMPRESSION CAMSHAFT and reinforced crankcases.
The FLX motor is manufactured and assembled as a 190 at the Daytona factory.
    Roller Rocker Arms
    10mm oil cooler connection
    Honda type exhaust port
    Lighting coil
Engine Includes:
    (1) Daytona FLX 190 engine with Lighting output stator
    (1) Intake manifold
    (1) Wire Harness
    (1) CDI: ( 4 selectable timing settings & 5 selectable Rev Limiter setting)
    (1) Ignition Coil
    (1) Intake manifold carb boot
*New Updated Features!:
    Improved decompression feature
    Reinforced crankcase design
    New clutch with new forged gear
    Improved CDI with a max 12900 RPM limit
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #59 on: June 27, 2017, 06:27:12 PM »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline grcamna2
« Reply #60 on: June 27, 2017, 06:32:40 PM »
That one looks like it has the large front drum.I like that little bike !
Offline strynboen
« Reply #61 on: June 28, 2017, 02:03:09 PM »
nice ..its a cd 50..like mine.. 2 bolt engine..he had thanged the fork..think to a zundapp..and the main light is from it too
« Last Edit: June 28, 2017, 02:07:11 PM by strynboen »
i hate all this v-w.... vords
Offline SKTP
« Reply #62 on: June 28, 2017, 03:43:32 PM »
I agree about the Zundapp headlight. I Wish I was a 2 bolt...but I think the frame-mods won't be too crazy and I am actually looking forward to the re-wire challenge. I think I have a line on a 68 CB350 Front end....I actually love the fork ears and the fork-covers and plan on painting everything on the bike Porsche Bahama-yellow...so lots of paintable metal on the fork is an added bonus...I wonder if the S90 finder will still fit? I do not want chrome...could I lace the 350 hub to an s90 rim? Lots to learn on this one
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline grcamna2
« Reply #63 on: June 28, 2017, 07:40:20 PM »
I would want the CB350K4(72')front end as the top triple uses pinch bolts and the fork tubes are the same O.D. all the way to the top;the K4 twin uses 'tins' also if you like them.
Offline SKTP
« Reply #64 on: June 29, 2017, 09:13:41 AM »
So you're saying I could lower the front at the triple like when people have their fork-tubes sticking up over the triple? I have a line on a 68 full front end (no wheel) for $100. Seem like it might be a good deal (waiting on condition photos)
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline grcamna2
« Reply #65 on: June 29, 2017, 10:28:32 AM »
Yes.
The 68' front-end has different triples which don't allow movement to slide the tubes up and the top of the forks are machined-down to fit into the top triple tightly;it doesn't used pinch bolts which I prefer as on the CB350K4-K5 twins.The CB350K5/G was the last year(73') for the CB350 twin and that one used a front disc caliper the same as the CB360 disc.and the CB350K5(they also called it a 'G')didn't have 'tins' as the previous ones.I think the CB350K4 twin w/ the drum front(last yr. for that nice drum)and top triple,tins was the nicest one plus you can install the front disc brake onto the left lower/slider from the CB350G to it which is the same as the CB400F and CB360: 18" front wheel.
« Last Edit: June 29, 2017, 10:31:12 AM by grcamna2 »
Offline SKTP
« Reply #66 on: July 07, 2017, 12:56:40 PM »
Inspiration photo
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline grcamna2
« Reply #67 on: July 07, 2017, 04:26:10 PM »
Yes !  That S90 has a nice CB125S motor w/ great looking(I'd install different tires for riding it though..) rims.That must have been a little work  8)  The caf'e seat looks excellent !
I'm curious what his front disc brake is ?
« Last Edit: July 08, 2017, 07:07:28 AM by grcamna2 »
Offline firebane
« Reply #68 on: July 08, 2017, 06:30:57 AM »
So your bike looks to come with 27mm fork tubes. You could look at something like a SR250 which has 32mm fork tubes and has drum and can easily take a 18" wheel.
Other option is to source GN125 forks which are 32mm and has a disc option.
Offline strynboen
« Reply #69 on: July 08, 2017, 10:49:37 AM »
Suzuki gn-??  those forks is far to long and too heavy build..my vife had one..braking vas real good..
Offline grcamna2
« Reply #70 on: July 08, 2017, 11:20:46 AM »
similar to a mini-chopper  :D
Offline strynboen
« Reply #71 on: July 08, 2017, 01:16:51 PM »
yes topspeed 60 miles/100 kmt 8) 8) 8)..so no speeding..save a lot of Money...
Offline firebane
« Reply #72 on: July 08, 2017, 01:19:55 PM »
I am trying to actually track down a set of forks and disc setup for a project of mine but we didn't get many of them up here in Canada
Offline strynboen
« Reply #73 on: July 08, 2017, 01:32:19 PM »
e bay germany.
.they had milions of them..even have a gn forum dovn there...or had..think it dyes aut this years.
..the tubes is thinvalled in the top..and have no theeds in the top..just a Lock ring..and a o ring to hold the oil inside..its a press dovn(against the spring) and remove the Lock system. and it jumps up.a bit tricy first time i thanged the oil..but solid and vell funktionel bike..
Offline SKTP
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
