Author Topic: exhaust flange torque  (Read 1715 times)
Offline lash
« on: September 28, 2016, 07:14:21 AM »
69 cb750... anyone know what the torque should be for the exhaust flange bolts?
Offline Bodi
Re: exhaust flange torque
« Reply #1 on: September 28, 2016, 07:33:10 AM »
Pretty sure they are 6mm - steel into the alloy head... so not much or you strip the alloy threads. There is a spec in the common service manual but I don't torque these to a spec, I tighten until the header gasket gives a little and then check for looseness after a few heat cycles. I haven't had them come loose after doing this.
Offline lash
« Reply #2 on: September 28, 2016, 07:39:19 AM »
Makes sense, thanks
  • I'm back
« Reply #3 on: September 28, 2016, 11:30:26 AM »
Just tighten by hand until gaskets are compressed somewhat and then stop. In case you have to redo it a bit, you'll still have gasket left that still can be compressed a bit further. Did it like this myself the other day. Torque wrenches on 6mm is madness, a mistake is easily made. It's not worth it.
Offline jonda500
« Reply #4 on: September 29, 2016, 08:16:15 PM »
+1!!!!
A starter clutch thread:
« Reply #5 on: September 30, 2016, 09:56:04 PM »
 Nonsense, tighten till it strips and back it off a half turn. That said, someone ripped the thread lug off a head recently, that one was apparently bottomed out, beware of that issue.
 In all seriousness I agree with the above advise.
Offline Airborne 82nd
« Reply #6 on: October 01, 2016, 04:23:01 AM »
Have you considered replacing them with studs & nuts like my 1978 750K But that's just me.
imho
Offline lash
« Reply #7 on: October 01, 2016, 06:03:14 AM »
No, I'm trying to stay as close to stock as I can.
