Installed m-Lock tonight, pretty nifty piece of equipment. Rechecked valves, couple intakes were a few thousandths over. Also finally read the instructions for the speedo sensor on the motogadget. It says quite specifically to use only one of the magnets. I stacked both of them together and used that. Also, gap between magnet and pickup is supposed to be less than a mm so I made a mount from layers of carbon fiber and bonded that to my front wheel to get .5mm gap. I'll double check the wheel diameter I used in the gauge, hoping that resolves it.
Also did reading on something I didn't understand, I have a clunking sound at idle. If it was a built car I would say it sounds like piston slap but it isn't consistent enough to be that. Can find a dozen threads on here about it, all recommending the same thing. Keep idle above 1050 (I have it a 900 right now), when the clutch goes in the sound lessens and synch the carbs. I didn't check the clutch thing but that sounds reasonable. Carbs are sync'd using gauge pins (and was told not to touch them) but I think I will hook up my carbtune and see what that results in. Also clearly need to raise my idle.
