Author Topic: Valve guide honing Q? Answer found.  (Read 5187 times)
« on: December 17, 2016, 08:28:47 PM »
 I bought a cb750 head with new Honda guides already installed and one stuck valve. I replaced that guide but now need to hone it and possibly other ones to fit the new valves. No one around here seems to want to work on a 750 so I ordered a 5.5 mm kibblewhite hone which seems to be the one for use on our bikes.
 I assume you simply hone it with light oil, clean it, check it, hone it, clean it,  check it, until the valve fits cleanly, clean and make sure there is a spec'd minimum of side clearance. Sound correct?
« Last Edit: December 29, 2016, 02:47:48 PM by Don R »
Re: Valve guide honing Q?
« Reply #1 on: December 17, 2016, 08:49:24 PM »
subscribed
Offline Big Jay
    • CBRzone
« Reply #2 on: December 17, 2016, 09:13:52 PM »
WE use a Sunnen guide hone and hone the guide to fit the Serdi pilot that we will be using to machine the seats.
« Reply #3 on: December 18, 2016, 05:33:51 PM »
That's the way
« Reply #4 on: December 18, 2016, 07:22:32 PM »
Of course that's the best way, possibly making this the next best way. L0L!
« Reply #5 on: December 18, 2016, 07:25:35 PM »
is the difference between a hardened tool steel valve guide reamer or a small ball hone ?
« Last Edit: December 18, 2016, 07:28:35 PM by grcamna2 »
« Reply #6 on: December 18, 2016, 07:56:56 PM »
I thought you had to cut new seats always after replacing a guide.  Is that not correct?
Thus, the response by Big Jay and Mike.
« Reply #7 on: December 18, 2016, 08:00:52 PM »
Correct. The valve center line moves after installing a new guide
« Reply #8 on: December 18, 2016, 08:20:44 PM »
Mike,
What brand valve guides do you use ?
Offline Big Jay
    • CBRzone
« Reply #9 on: December 18, 2016, 08:41:33 PM »
« Reply #10 on: December 18, 2016, 09:10:33 PM »
Big Jay,  do you have a similar page or product listing for the CB550?
David
« Reply #11 on: December 18, 2016, 09:12:29 PM »
 I'm hoping the other guides and seats were done correctly, it changed hands a couple times before I got it so I can't ask. My plan was to get the valve in, dye the seats and hand lap it in, check the pattern and then call for help if needed. It's for my K0 engine and I don't have a proper cylinder yet anyway.
Offline BPellerine
« Reply #12 on: December 19, 2016, 10:07:30 AM »
I don't know a lot about this but hondaman says 6.5 reamer and finish hone,now ape sell a 5.5 hone and a 7mm hone,which one ?be nice to know for those of us who don't have the good stuff available to us.bill
1978 CB 750K ard and webers
another anfob
« Reply #13 on: December 23, 2016, 02:35:16 PM »
 Well, the 5.5 hone is obviously intended for the 5.5 kibblewhite undersize valves and their guides. Pretty useless for stock Honda valve guides. I'm thinking 6.0?
« Last Edit: December 23, 2016, 02:37:17 PM by Don R »
Offline Big Jay
    • CBRzone
« Reply #14 on: December 23, 2016, 07:48:27 PM »
We don't ream guides. Our guides have a high nickel content for wear, and will wipe out most reamers.
« Reply #15 on: December 23, 2016, 09:03:58 PM »
Easiest  and cheapest for Joe Average... Ball sizing... Should work..
« Reply #16 on: December 23, 2016, 09:24:09 PM »
 I don't even know what that is. I see APE lists 5.5 and 7 mm hones.
« Reply #17 on: December 23, 2016, 09:44:49 PM »
You get a precision sized ball, force it thru the hole..done .
If you get the right size ball.
« Reply #18 on: December 24, 2016, 03:34:17 AM »
My ports got even more grinding job when the 5mm conversion kit went in. The guides aligned different and only seat cut was not enough according to the guy that ported it 1983. He smiled when he could do more work on it 33 years later :)
EDIT: The additional work done was visible before valves went in, closer to the seat and seat itself. More flow  ::) Hopefully better....
« Last Edit: December 24, 2016, 03:40:22 AM by PeWe »
« Reply #19 on: December 24, 2016, 08:56:29 AM »
 That should flow some air.
« Reply #20 on: December 29, 2016, 02:46:16 PM »
It's all here if you can just find it, I ordered a .259 reamer.  And while I was at it I learned to read my micrometer with my glasses on. My exhaust valves measure new spec .259" so they're going to be plenty tight that's 6.58mm for those keeping score.
http://forums.sohc4.net/index.php?topic=127377.0
« Last Edit: December 29, 2016, 09:40:15 PM by Don R »
Re: Valve guide honing Q? Answer found.
« Reply #21 on: January 25, 2017, 09:03:35 PM »
 The exhaust valve fits nicely, after the reaming. I didn't think the exhaust stem would be slightly smaller, it is. Not pro quality but i'll check the seat with my old neway.
