some do mod the slides,when running pods or similar,they grind them a bit ,in hopes of making them work better,dont know if that is the case with yours.bill
Not to open a can of worms, but have you considered worn "needle jets" and "jet needles"? A worn spot on the needle(s) can occur if the bike has a lot of city miles, where the throttle is in and out of that 1/4 range frequently, and whenthe engine is shifted a lot. The needles are in nearly constant contact with their jets. Just throwin that out there as a suggestion. I went thru this before, but replacing the needles and jets was done as my last resort. Have you tried raisingor lowering the needle position? that can put the worn spot of the needle (if present) higher or lower in the jet. Grinding throttle valves will definately affect tuning if it has been done tho. A "Don't try this at home" kind of thing
Quote from: DH on January 24, 2017, 08:57:17 AMNot to open a can of worms, but have you considered worn "needle jets" and "jet needles"? A worn spot on the needle(s) can occur if the bike has a lot of city miles, where the throttle is in and out of that 1/4 range frequently, and whenthe engine is shifted a lot. The needles are in nearly constant contact with their jets. Just throwin that out there as a suggestion. I went thru this before, but replacing the needles and jets was done as my last resort. Have you tried raisingor lowering the needle position? that can put the worn spot of the needle (if present) higher or lower in the jet. Grinding throttle valves will definately affect tuning if it has been done tho. A "Don't try this at home" kind of thing
Hard to tell, but are those the emulsion tubes or the needle jets?
Nope.. Main jets screw into the emulsion tubes. The needle jet is in the body of the carb that the needle passes through. Any parts fiche will show you better than my description 😉
if necessary I have a broken down set of parts carbs I would let go cheap to help get your working again. have all 4 slides and stock needles and carb bodies.....my parts set is missing all the racking brackets and throttle linkage arms and rods, but the individual carbs are all there.
I'm just walking in here but I don't see any of the basics covered here at all.Carb settings, (jets, needles, mixture, etc.)Bike mods, bike year, etc.
ok, keep in mind that changing the needle position which is what needs to be adjusted to address your problem will affect everything else. which means, you'll have to just retune again anyways.
Does the needle position affect the idle as well? If so by how much?
