Author Topic: CB550K Loses Electrical Power in Upper RPMs  (Read 1322 times)
Offline VigCS
« on: January 23, 2017, 04:51:31 AM »
Hi all,
I posted this in my other thread about jetting, but figured I'd start a new topic to get more exposure.  My CB550 is having an odd electrical symptom.  When you hold the throttle wide open it'll rev up to around 6,500 rpm and seemingly lose electrical power.  The exhaust will crackle and pop, and as soon as you let off the gas the power will come back and it will go back to idle.  This has been thoroughly confused.  Here's a video of it happening:
Any ideas?  Thanks!
'78 CB550K, 2004 KLR650
Offline b52bombardier1
Re: CB550K Loses Electrical Power in Upper RPMs
« Reply #1 on: January 23, 2017, 05:08:06 AM »
Very bizarre.  Do you have a multimeter?  Connect it up to the battery and run a few DC and AC voltage measurements there with the bike running at idle and at that high rpm speed.
What does your meter say at those points?
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #2 on: January 23, 2017, 10:55:35 AM »
At first i thought "points bounce" maybe...then I saw the indicator and headlight do that thing...yikes.
Motor sounds good otherwise.
I'm with b52, suspect vreg and rectifier are getting out of whack once the stator/fc start ramping up.
Which reminds me, I should probably dial back my omp vreg some too...headlight wants to oscillate at upper rpm too...but it hasn't limited my revs like that...
Hmmm.
Are you using oem points breakers?
Offline VigCS
« Reply #3 on: January 23, 2017, 12:30:47 PM »
Hmmm.
Yes, they're OEM breakers as far as I know.  I've got an extra ignition plate as well (with new points, condensor, etc...).
Would a voltage regulator or rectifier getting out of what cause loss of power at RPM, or excessive power?  Or both, depending on the situation?
I'll give the exercises you guys suggest a try tonight and report back.  Thanks!
« Last Edit: January 23, 2017, 12:33:45 PM by VigCS »
« Reply #4 on: January 23, 2017, 02:41:26 PM »
I notice there is no key in the key switch...so you must have bypassed it somehow.  Are you sure you have done this correctly with good tight connections?...cause it really sounds to me like engine vibrations are disturbing a loose connection.
Offline Deltarider
  • I'm back
« Reply #5 on: January 24, 2017, 03:02:16 AM »
That was my first thought too.
CB500K2-ED Excel black
Offline VigCS
« Reply #6 on: January 25, 2017, 07:09:26 AM »
The ignition barrel recently broke - the glue on the little plastic rotator piece that fits inside the key barrel broke.  The plastic piece is underneath the key and I was just rotating it to the ignition position - but that may be worth checking out.  I need to order a new one.
I also tried it again last night and, of course, couldn't reproduce the problem.  I did recharge the battery in the process, though, so maybe the battery was just weak?  I also checked voltages revving it up.  It was getting to 12.9 - 13.0 v at 3,000+ RPM (which honestly seems a little low).
Offline VigCS
« Reply #7 on: January 25, 2017, 08:14:03 AM »
I'll check again tonight, but I checked it through the rev range up to about 7,000 and never saw higher than 13V.  I may try another volt meter just in case since I was using a crappy harbor freight one.  Here's a video of me checking the voltage:
Looks like it doesn't go past 12.84V in that video, and I definitely revved it past 5,000.
« Last Edit: January 25, 2017, 08:19:51 AM by VigCS »
« Reply #8 on: January 25, 2017, 09:30:14 AM »
I would assume that key switch is the vast majority of your problem.  It is easy to bypass for checking, then check your charging system.
Offline VigCS
« Reply #9 on: January 25, 2017, 12:09:35 PM »
I guess I'm not quite understanding how it can be a problem.  Are you thinking when it revs the vibrations jiggle it such that it's momentarily cutting the ignition out?  Either way, it seems like the charging system isn't putting out quite enough juice...
  • Holy Cow! I'm a
« Reply #10 on: January 25, 2017, 12:40:11 PM »
Yeah, bad vibes would make an intermittent short.  Its worth checking the connections anyway.  A simple loose connection could undermine the results of other charging system tests.
« Reply #11 on: January 25, 2017, 01:52:45 PM »
I too don't think a bad ignition key is preventing your charging system from reaching its potential. More than likely, you have a loose ground or corroded connection somewhere thats not returning charge status back to the battery.
It sounds as though you might need to perform some diligent maintenance on your entire wire harness, electrical connections, and charging components.
yup
