Author Topic: Lost front turn signal wire  (Read 882 times)
Offline JBCB500
  • Really enjoying this!
« on: February 15, 2017, 10:00:50 AM »
Folks,
I am finishing up my total rebuild of my 1971 CB500 and I seem to have missplaced the wire that runs through the tube leading to the head of the turn signal.  I remember removing it as the previous owner had cut it too short and I had planned to replace it or lengthen it with a soldered extension.
I am trying to describe the wire that terminates in a small round plastic piece that the turn signal bulb sits against.
Is there a way to make one of these or am I stuck trying to find one online?
And finally, my front signals came with only one wire each, how are these supposed to ground?
Re: Lost front turn signal wire
« Reply #1 on: February 15, 2017, 10:11:55 AM »
http://www.cmsnl.com/honda-cb500k1-four-1972-usa_model460/partslist/F++26.html#results
One wire is hot and the bulb grounds to the frame through the socket/stalk for the fronts.
The rears ground on wired #11/12 pictured below.
Parts #s for the sockets are in the link above
« Last Edit: February 15, 2017, 10:28:12 AM by flybox1 »
