Author Topic: Crank shafts and piston arm bearings  (Read 2687 times)
Offline Xcmandan
« on: April 20, 2017, 10:10:22 AM »
Is it absolutely necessary to plasti gauge to fit new bearings??? Or can I just get new ones and install them? I know pictures can't answer this but just showing what bearings I'm talking about.
Thanks
Sent from my SM-G900V using Tapatalk
Re: Crank shafts and piston arm bearings
« Reply #1 on: April 22, 2017, 07:07:06 PM »
Plastigage, or do it with ID/OD measuring micrometers.
Plastigage is cheap and accurate. ;)
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #2 on: April 22, 2017, 07:42:47 PM »
Have the journals on the crank been measured? If it has very little wear you may be able to get away with std bearings. Verifying with plastigage is always good insurance.
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
Offline Xcmandan
« Reply #3 on: April 23, 2017, 10:55:35 AM »
Thanks. No I haven't measured the journals yet. I have a standard micrometer. I'll measure it tomorrow
« Reply #4 on: April 23, 2017, 11:09:33 AM »
Good engine building takes time and careful measuring and assembly...
Do you want a good one? Do you want to know what you got ? Do you want to know if its at the ragged edge of needing replacement ?...or that it should be good for years of more miles.
 The choice is your.....
Offline Xcmandan
« Reply #5 on: April 23, 2017, 11:22:20 AM »
754 thanks Bro. Yes I want years of use out of this bike. It's my first build. You guys and my manuals and youtube are my only sources of knowledge.
« Reply #6 on: April 23, 2017, 11:30:45 AM »
My take is measure AND then Plastigauge to backup your measurements.
Offline Xcmandan
« Reply #7 on: April 23, 2017, 04:19:30 PM »
I'm amazed at all the knowledge in you guys. Thanks!!
« Reply #8 on: April 24, 2017, 06:46:07 PM »
I'm not much at "sales", but...you might want to get my book? It takes you step-by-step thru the things you're doing...or about to do. ;)
Offline Xcmandan
« Reply #9 on: April 24, 2017, 07:21:47 PM »
HondaMan, I've heard a lot about your book. I'm on a tight budget though and have 3 manuals as of now. Gobs of special tools and some I just needed in general. Spent a few hundred and have bought a single part yet. Also i have to have the case inspected due to finding it was cracked and welded prior to me buying it. Bad welds too.
« Reply #10 on: April 24, 2017, 09:21:52 PM »
YEOW! That is a poor job!
I suspect you may find it cheaper to get another set of cases than to have that one fixed up and re-ground flat enough to stop leaking again. Reason I say this is: while I have [once] seen a repair there where someone milled down that area where your plate is now welded in, so as to fit a rubber gasket over the area in the hope of sealing it (which did sort of work, to his credit), when the chain became a little bit loose (and he was running the normal 18T front sprocket, close quarters) it chewed up his nice little rubber gasket and re-started the leaking problem. He later swapped cases, but in the 1970s these were mighty hard to come by! Today they are quite available: you can often buy another engine for $50-$150 that doesn't run, and use the cases and all the other stuff as spare parts.
For a "perfect swap" scenario, find an engine with the first 2 serial numbers the same as yours (That is, after the "CB750E-" part of the number). For example, the "..23--" series was the first of the injection-molded cases, which became the "..24--" and "..25--" series cases, which were the most accurate ones made. If yours starts with "..23--" you can use either the "..24--" or "..25--" as direct replacements, as the ball-bearing grooves will all be in the exact same places. If you have a "..24--" or "..25--" case, you can still use all the way 'back' to the "..23--" case IF the case has the wide support area with 2 grooves for the output shaft bearing for the countershaft (nearest where yours is now broken). There are even a few of the last of the K2 cases "..22--" that have both grooves, too. These will give you the least grief in swapping them.
If your engine is earlier than the K3, or even a very early K3 (which was an "Old Factory" K2 leftover), the web where yours is broken will be thinner than in the later cases. These early cases have only one groove in the countershaft bearing area, and a narrower face to hold the bearing: these cases use a 1-row ball bearing and a different output shaft from the later engines. The later ones have a 2-row ball bearing at this site, hence the major difference. The last of the K2 and some of the early K3 engines had 2 groves at this site to fit EITHER the 2-row OR the 1-row ball bearing, with their different shafts.
All this said...you can also swap the output shaft for the "other one" if it came to that, and all the other parts will fit fine. I have some dual-row output shafts around here somewhere, from engines that otherwise died or were modified to use the 1-row bearing shaft, for racing purposes (it saves some extra HP at heavy throttle settings and high speeds).
If your engine is the 1975 "F0" or later, you will need cases as follows: for F0, you need F0 cases, sorry...for F1 you can use F1 or K7 cases with no troubles. For K7 or K8 you can use K7 cases: K8 cases will usually have fussier setup issues with the spacing on the mainshaft's bearing on the side opposite the clutch, so that can be tough for a newbie to have to live thru? For F2/3, use the black F2/3 cases, and those interchange  fine. I have also successfully put F2 into K7 cases, with nothing more than some crankshaft bearing size changes.
Beware when buying cases: ask to see photos of the very same area where yours is crashed. There's lots of cracked and broken ones out there. Cracked can be fixed, broken is hard to do so - as you're learning! :(
« Reply #11 on: April 25, 2017, 09:02:09 PM »
One case half looks like the piece is still there, easier to fix.
 The one with the thin plate is it the top half..? Might be able to supply a piece.
Offline Xcmandan
« Reply #12 on: April 25, 2017, 11:06:19 PM »
Yes it is the top half of the crankcase.
« Reply #13 on: April 28, 2017, 12:10:28 AM »
Drive chains of today are stronger. I snapped a DID 50HDS o-ring chain  for soon 30 years ago when gearing down from 5 to 3 + wot in around 120kmh. Main reason then was a sloppy chain. Case got only a scratch beside the sprocket. That's why I have the strongest golden X-ring chain I could find when restoring the bike 2013.
Broken cases due to crappy chains or in combination with leaking battery.
My chain in today do not stretch as the o-ring chains from the 80's
Offline Xcmandan
« Reply #14 on: April 28, 2017, 07:16:21 AM »
My engine is a 77 F2. Ser.num..2101133. I have located a 78 f engine online but don't know much about it. I may explore that Avenue this weekend. My cases are at a machine shop this week. I'm waiting on a estimate for welding/fixing the bad area. About the other engine....the guy wants $300 which I think is ridiculous. Going to tell him 100 tops. We'll see how that goes.
« Reply #15 on: April 28, 2017, 08:45:59 AM »
Before you tell him..late F motors seem to go for more than most Ks.
Not unusual to see 150 or more price on just the head. A desireable casting
You can always sell the head, get some cash back. 77/78 f cases are black.
 The tranny ratio are a bit different, but it works.
