The 405 is just a casting number. Always replace the upper and lower cases as a set for best bearing alignment. Since your motor will be apart, I would advise checking the valve-guides for wear.........especially if 18000 miles or higher. If you get a complete motor and just swap.........you may have some top-end parts to sell. If you miss your opportunity, I have a set of cases or a complete motor available in Wisconsin.
