Author Topic: Molasses Rust Removal  (Read 1431 times)
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« on: June 05, 2017, 10:53:31 AM »
I am using a 6:1 mix of Water/Molasses to de-rust a fuel tank inside. Only thing I cannot find is a definite answer on how long to leave the mix sitting inside. Anybody?
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
Re: Molasses Rust Removal
« Reply #1 on: June 05, 2017, 11:04:32 AM »
A week....maybe.  That's a slow process.
Slow.
....like molasses.
Vinegar is faster.  So is prep-n-etch.
Both are safe for paint.
« Reply #2 on: June 05, 2017, 11:11:56 AM »
It's still an acid.  Eats rust and metal with indiscretion.  Thins metal encourages pin holes.
Offline PlungerWaffle
« Reply #3 on: June 05, 2017, 11:49:46 AM »
I use vinegar and pea gravel. Cleans it up in a matter of minutes. Leaves your arms sore though, and there might be a risk for holes but successful the few times ive tried it.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #4 on: June 05, 2017, 11:56:36 AM »
This stuff will clean the molasses and the rust out.
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #5 on: June 05, 2017, 12:38:14 PM »
I do have a procedure for cleaning the tank after the molasses treatment. What I do not have is an idea about how long I have to leave the mix in. It seems a week may be the answer. I heard it depends on the mix ratio.
1973 CB350F -sold
Other Hondas:
3 x CBX
CB1100R
GB500
Offline Deltarider
« Reply #6 on: June 05, 2017, 01:52:33 PM »
I'd start with the easiest (and least harmful): pour in a litre of diesel and move it around and see where that gets you.
CB500K2-ED Excel black
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #7 on: June 05, 2017, 02:56:49 PM »
So, has anybody used molasses and water? How long?
1973 CB350F -sold
Other Hondas:
3 x CBX
CB1100R
GB500
Offline Bodi
« Reply #8 on: June 05, 2017, 03:38:49 PM »
Look for "Tubalcain" on youtube. He has a series on rust removal including molasses. Might have some clues on how long. I think it was the poorest of all the things he tested.
Offline jonda500
« Reply #9 on: June 05, 2017, 04:08:53 PM »
It not only depends on the mix ratio but also on the ambient air temperature. I leave the "part" soaking in molasses for several days or more, good to clean up thoroughly halfway through and put back in to finish. The bubbles/froth floating on top tell you it's working, when the rust is all eaten the froth stops. I did not notice any not rusted metal get eaten at all?
John
Who can guess what two items I am derusting below?
A starter clutch thread:
Offline eigenvector
« Reply #10 on: June 05, 2017, 04:51:23 PM »
Seat pan and something else.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline jonda500
« Reply #11 on: June 05, 2017, 06:22:12 PM »
yep, and battery cage :)
John
