Author Topic: anyone knowledgeable with newer camaros?  (Read 1331 times)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« on: June 19, 2017, 09:15:40 PM »
my wife has a 2011 camaro, v6, manual trans, 41k miles.  the previous owner put on an aftermarket intake to replace the stock air box.  they built it so that the air cleaner is way down in the fender well, low to the ground.  i've been meaning to replace it with a stock air box or a k&n intake that would be higher up in the engine compartment.  well my procrastination has bitten me in the ass.  we took a sunday drive yesterday and got caught in a major downpour.  on the way home the car started bucking, running rough and the CEL came on as well as Service Stabilitrak.  we made it home.  the intake sucked up water and fouled the maf sensor.  luckily no water got to the motor.  so i took the intake apart and sure enough full of water.  dried it all out.  cleaned the maf sensor with maf cleaner and reinstalled everything.  car runs perfectly fine now however the p0100 code (maf sensor) and service stabilitrac won't clear.
could the maf sensor have gone bad even though the car seems to run fine now after cleaning it?
« Last Edit: June 19, 2017, 09:17:13 PM by evinrude7 »
cb750 k6 - ugly
Re: anyone knowledgeable with newer camaros?
« Reply #1 on: June 20, 2017, 03:54:26 AM »
 Does disconnecting the battery for a certain length of time help to clear those codes ?  I was reading about clearing a code once and there was some trickery involved with the ignition switch,turning it on x amount of times,making a sacrifice of a goat and other things  :D  Maybe the dealership or autoshop may have some friendly advice.
Offline innovativems
    • Innovative MotoSports
« Reply #2 on: June 20, 2017, 04:43:40 AM »
 Could have fouled the maf.  Got any buddies with a scan tool that will test it?
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline Monkey_King
« Reply #3 on: June 20, 2017, 04:45:18 AM »
Leaving the battery disconnected will reset some codes.  However in your case it's maybe maybe not.  Check the camaro5 forum for better information
Offline evinrude7
  • not a kung-fu
« Reply #4 on: June 20, 2017, 06:22:04 AM »
Most every local auto parts store will read, and some will reset, the codes for you. It's quite possible the deluge actually damaged the Stabilitrak sensor due to immersion.
i've run through all the tricks and gimmicks, no luck.  father inlaw has an obdII reader and attempted to reset codes after reading p0100 which was after the fact of drying everything out and cleaning sensor.  wife ran the vehicle for a good length of time to hopefully achieve "drive cycle".  warning lights still on.  i'll pick up a new sensor today and see if that does the trick.  thanks for the input.
cb750 k6 - ugly
« Reply #5 on: June 20, 2017, 07:12:33 AM »
I bet you will be set.  The maf sensor are very finicky when they get dirty and even wet.  Keep us posted and good luck.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #6 on: June 20, 2017, 09:37:51 AM »
I picked up a cheap bluetooth code reader for under $10. I can read the codes and reset them using it and my cell phone.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #7 on: June 20, 2017, 10:43:53 AM »
Wow got a link? I was going to suggest a cheap ODB II reader from Harbor Freight works great but for $10, you can't beat that price.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline evinrude7
  • not a kung-fu
« Reply #8 on: June 20, 2017, 04:39:49 PM »
link please.  yes it's all fixed.  $100 for a maf sensor.  stabilitrak lights went off as did CEL.  soon i'll need to find a stock airbox or a k&n kit.  feeling lucky we didn't suck water into the motor.  til then we'll use the truck on rainy days.
cb750 k6 - ugly
