Author Topic: Oil leak where clutch cable connects to clutch?  (Read 1690 times)
Offline Christopharx
« on: June 29, 2017, 06:37:15 PM »
Hey guys, back at it again with the 1982 CB750C. I've been learning my way through the bike (the wiring was a mess, turn signals, new battery and solenoid, signal relay, ect.)
So I did an oil change and all seemed well, ran it for about a day with no issues, but today I noticed a significant leak where the clutch cable goes down towards the clutch, right where it connects; you pull the lever on the handlebars and it moves up and down right on the side of the clutch cover. It's leaking a decent amount and caused quite a bit of smoking on my exhaust wraps. I'm not too quite sure why it's leaking now, as I've just dealt with my oil filter leaking after an oil change. Is there supposed to be an O ring on there? How do you go abouts fixing it? Is there a part number or something for any o-rings or sealant or a gasket? I checked Ebay and Vintagecb750 with no luck in location what it might be.
(I've attached a picture of where I'm 89.67% sure it's leaking from.)
Thanks again for your knowledge and assistance! :)
Re: Oil leak where clutch cable connects to clutch?
« Reply #1 on: June 30, 2017, 04:56:13 AM »
I've attached two more close up pictures. If I find the o ring that looks like it should go there, how in the world do you put it on?
« Last Edit: June 30, 2017, 06:17:25 AM by Christopharx »
Offline kevykev66
« Reply #2 on: July 03, 2017, 02:49:15 PM »
Looks like you got a blown oil seal sir. #11 on the attached pic
Go here to see the part , but you can probably source it closer to where you are.
https://www.cmsnl.com/honda-cb750c-750-custom-1982-c-usa_model7239/partslist/E++07.html#results
« Reply #3 on: July 07, 2017, 04:08:33 PM »
Got it, that diagram helped. Thanks!
« Reply #4 on: July 08, 2017, 01:35:13 PM »
oil level korrekt?? engine breather free and open..so no pressure builds up...normaly ve dont have leaking from there..on aur older sohc bikes..
