Here an important note about Electronic Ignition that can explain some bad experiences with EI.
Go electronic all the way, charging system included for a stable voltage. I doubt that the 69-78 have a stable charging.
https://www.dimecitycycles.com/charlie-s-place-electronic-ignition-system-honda-72-74-cb350f-75-77-cb400f-71-73-cb500f-74-78-cb550f-and-69-78-cb750.html
*All models manufactured before 1969 do not have a regulator as a stock feature of the charging system. While this does not matter with a points type ignition system, it is incompatible with the upgraded electronic ignition system. The electronic ignition system requires a steady regulated voltage to function properly. Bikes that do not have a voltage regulator will burn out the electronic system. Therefore, if you wish to use this system with your pre-1969 bike, it is mandatory that you upgrade the charging system.
*On models that do not have a regulator as a stock feature, you must purchase a single-unit regulator/rectifier (Type 1) to use this ignition.
Electronic ignitions are not compatible with non-regulated systems.
Here is another important note to go along with the above important note:
If you install a voltage-forcing regulator on a current-limited alternator system (as is found on all Hondas prior to 1979 except the CX500/650), there will be a price to pay for it, in terms of power generation. Either the peak voltage must be lowered to the point where the alternator can run cool-ly enough to survive, or else the alternator's life will be significantly shortened by the heat of being forced to raise the voltage to an arbitary value that someone 'wants', like 14.0 volts, to run a given accessory.
The reason for this is actually pretty simple: the alternators were made with lacquer-based insulation enamels that can withstand temperatures up to 200 degrees F. This is why the alternators on all these bikes are "dry", not oil-bath types: the oil can get hotter than that, so the alternators are set higher than the oil level, and in their own enclosure, out in the wind, to keep them cooled off. While they get a little bit of oil splash, they are not heated by immersion in the oil. If you then increase the current load in the alternator, it heats itself up, higher than the enclosure where it lives. The aging 200 degree lacquer won't appreciate this...
So, for my 2 cents' worth: if you upgrade to a "modern" voltage-forcing electronic regulator to support a new electronic ignition, consider also upgrading to a brand-new OEM alternator, which will now bear more modern epoxy-based insulation that can withstand up to 280 degrees F temperatures. Then it will be both higher voltage AND reliable long term, and not leave you sitting in the summer heat out in the boondocks, wondering if you have cell-phone coverage that can help you find a pickup truck with a ramp...
Or - just use my Transistor Ignition, which works from 6 to 24 volts, and doesn't care WHAT kind of alternator you have. That way, if you fill it up with water in the rain or carwash, you can just unplug it, plug the points back in, and ride home to wait until it dries back out.
