Author Topic: oil seal ?  (Read 777 times)
Offline gbal06
oil seal ?
« on: September 18, 2017, 05:41:38 PM »
This is probably a stupid question but For the oil seals that are positioned between the two crank halfs, are you guys using a sealer around the oil seals or are they just "pinched" between the two halfs? TIA
Offline DaveBarbier
Re: oil seal ?
« Reply #1 on: September 18, 2017, 06:21:36 PM »
Not sure which oil seals you're talking about (ones for the crank shaft or by the transmission) but I install them all dry. I use OEM seals. Some people use Hondabond or equivalent, can't do any harm as long as you only use a very thin coat.
I'm not quick when closing case halves so I don't want to use a hardening sealer and have it set before it's squeezed by the cases.
Offline gbal06
Re: oil seal ?
« Reply #2 on: September 18, 2017, 06:28:04 PM »
those are the exact ones I am talking about.  I pulled the motor and the washer that was on the main transmission shaft the covers the needle bearing and the oil pump bearing had a liquid gasket applied to it
Offline przjohn
Re: oil seal ?
« Reply #3 on: September 18, 2017, 06:30:59 PM »
I also install them dry. Did a 750F and used Hondabond on the Countershaft Seal. It caused it to pop out when assembling the cases. I can't recall ever reading any manual that says to put a sealant on a case seal.
Offline gbal06
Re: oil seal ?
« Reply #4 on: September 18, 2017, 06:51:03 PM »
I didn't think so and cant find an area in the manual that mentions how to install the seals
