Author Topic: Re-use Conrod bolts  (Read 1529 times)
Offline HondaYo
Re-use Conrod bolts
« on: September 21, 2017, 12:07:14 PM »
Need to take my crankshaft apart in order to swich transmission chain.
 I´ve read that using old bolts for the big ends is Never an option. Allways get new ones because of the fact that they "stretch to hold"
Any opinions and/ or bad experiences about this.
Locktite?! I have to blame my own stupidity that I didn´t put a new chain in when I rebuilt the motor this spring.
Allready know the final answer, but I´m curious if anyone has tried :)
Cheers
Re: Re-use Conrod bolts
« Reply #1 on: September 21, 2017, 12:10:37 PM »
Whats preventing you from just sliding the chain over it?  :-\
« Last Edit: September 21, 2017, 12:32:13 PM by flybox1 »
Offline HondaYo
« Reply #2 on: September 21, 2017, 12:30:08 PM »
The connecting-rods. I have the bottom half of the engine off. Sliding the camshaft out so I can remove the crank with the camchain and leave the head and cylinders with the pistons assembled. Working on the tranny so there´s no reason to take apart the top in my opinion.
« Reply #3 on: September 21, 2017, 12:33:16 PM »
I see.
I reused the bolts on my build, and just double checked my torque.
« Reply #4 on: September 22, 2017, 03:35:28 AM »
i just bay a new thain...its easy to pull the valve cover..and brake the chain..and put a new closed thain inn..then you have no vorryes of any link go bad..
have the crank aut gives a easy thange of these parts..and nev sealings/simmerings om the crank ends..they have dots..so no vay to thange them later..they are locked in the cases
Offline magnum56
« Reply #5 on: September 22, 2017, 11:17:12 AM »
I also reused my connecting rod bolts.
I don't subscribe to the thought that Honda made the rod bolts so weak,  that they should be unusable once torqued to specification.
'74 CB750K
Offline HondaYo
« Reply #6 on: September 22, 2017, 12:38:23 PM »
I agree! As I remember they are torqued to about 35-40 Nm (got notes somewhere) and that should not stress the life out of any bolt used only once..... But then again.
 I´ll give it a go and if my motor turns inside out, I´ll post a nice album for everyone to enjoy :)
Cheers
« Reply #7 on: September 22, 2017, 12:58:44 PM »
 After what my 836 went thru with stock rods, I would not even  worry about it on a stock motor.
« Last Edit: September 22, 2017, 04:30:16 PM by 754 »
Offline Nic
« Reply #8 on: September 22, 2017, 03:25:33 PM »
He's wanting to change the primaries not the cam chain.
I've re used plenty of rod bolts with never a problem. If it's a big yee haa engine then prolly would but then you'd be using better rods as well.
Offline HondaYo
« Reply #9 on: September 22, 2017, 06:40:50 PM »
Thank You Gentlemen. Feeling quite confident reusing the old bolts now.
 Got the crankshaft out letting loose the camchain from the camshaft and disconnecting the conrods with O-rings holding on to the bolts not allowing them to fall into the upsidedown pistons which are siting untouched in the barrels with the top on.
It´s allmost to easy. I could do this every Friday :)
 Letting loose the Firestorm tomorrow if the wheather gets any less rainy.
Enjoy Your weekend!  8)
