Author Topic: My first complete build 72 CB750 - completed for now...  (Read 64467 times)
Offline Davez134
Re: My first complete build 72 CB750 - color scheme ?
« Reply #100 on: March 12, 2018, 09:16:50 AM »
Wow! A Carpy bike??!  :-X
I thought the same thing haha! (as in "them's fightin' words")
« Last Edit: March 12, 2018, 04:40:49 PM by Davez134 »
« Reply #101 on: March 12, 2018, 10:13:38 AM »
Everyone has their own aesthetic.  IMO, I think that the bike in its final configuration was pretty distinct from his bikes (note: GL front end, numerous performance upgrades, electronics, custom rebuilt wheels, finishes, custom metal work, etc.).
Offline algophobe
« Reply #102 on: March 12, 2018, 12:07:22 PM »
finally perused thru the thread for your build. I'm tired for you just reading thru it. can't blame a novice for not noticing the "details in the devil". but hey, you kinda though of carpy first when you decided to go for it.
Ducati Hypermotard 950 SP 2020 "Percolo"
Honda cb750 café 1972 "Satmui"
Kawasaki zx6r 2005 "Garuda"
Kawasaki zx7r 1998 "Dharma" (stolen)
Honda Magna V4 1982 (sold)
« Reply #103 on: March 12, 2018, 04:23:20 PM »
Indeed, it its first evolution.  That bike literally had 9 lives.
Offline algophobe
« Reply #104 on: March 12, 2018, 05:11:48 PM »
you mind if i asked what kinda work you do? that's quite a bit of coin to pour into a project.
« Reply #105 on: March 12, 2018, 05:41:29 PM »
Contract killer.
« Reply #106 on: March 12, 2018, 06:36:34 PM »
Hey I just re-read your Nine Lives bike build thread Don, what a pain that must have been! Whatever happened to those Lockheed brakes? I wouldn't mind trying some on a CB750, and I thought maybe larger disc rotors maight solve the problem with the calipers hitting the spokes? Cheers, Terry. ;D
I traded them to my buddy (for him to use). I agree that if you could offset the rotors more than on the 750, you could probably use them.
Thanks Don, what I was thinking was using a bigger OD disc rotor, I had the same issue when I installed a PM caliper on the front of my Sporty, I couldn't lower it down enough on the disc without touching the spokes, so I found a rotor that was 20mm larger. The disc on a K2 runs very close to the fork leg, so not much chance of offsetting it away from the spokes. Cheers, Terry. ;D
Offline algophobe
« Reply #107 on: March 12, 2018, 08:57:05 PM »
Contract killer.
True that.  ;D
in that case, I sincerely apologize for all the insensitive words... and beautiful bike.. and you're beautiful too.. blessing.. go in peace. ;D
« Reply #108 on: March 12, 2018, 11:59:23 PM »
Contract killer.
True that.  ;D
Careful mate, while Don's a professional contract killer, he hates being patronised. Don't ask me how I know........... ;D
Offline algophobe
« Reply #109 on: March 30, 2018, 09:07:03 PM »
A little update. Started the painting after setting up a makeshift spray booth in the work shed. I'm using House of Kolor paint. After some Bondo work to fill up all the dents that was in the tank from previous owners. Primer and guide coat sprayed.
« Last Edit: March 30, 2018, 09:10:16 PM by algophobe »
Offline algophobe
Re: My first complete build 72 CB750 - painting begins
« Reply #110 on: April 10, 2018, 10:04:42 AM »
After some sanding of the guide coat and second round of glaze filter.  the smaller imperfections are filled and smoothed out.  Back to the booth for new coats of primer.
« Reply #111 on: April 10, 2018, 03:31:46 PM »
Looks like a scene from "Dexter"! ;D
Offline algophobe
« Reply #112 on: May 04, 2018, 03:34:58 PM »
finally had some time to make major progress on the painting. the tank went thru 4 cycles of thing body filling, primer and sanding to get the contour right to hide all those prior dents. for paint, I used House of Color Shimarin 2 system, simply because I had some paint left over from last time (mental note use less expensive paint next time). I've got the base color and first set of clear coat on them. It was quite a race trying to get to base coat on within the same window of sealer placement to clear coat. I certainly forgot how unforgiving body painting is.
Next is the 3rd and 4th layer of color on the tank and tail. while I do sand down the light and front fender to put on a final flow coat.
« Last Edit: May 04, 2018, 03:39:00 PM by algophobe »
« Reply #113 on: May 04, 2018, 05:45:13 PM »
Hmmnn, well I like the yellow and the white mate, but not keen on the battleship grey. Good job, and as long as you like it, that's the main thing. ;D
Offline algophobe
« Reply #114 on: May 04, 2018, 06:55:58 PM »
For some reason I've been on this kick for nonmetallic browns and greys. Its to enhance the yellow and white. Once the black comes in it'll pop even more.
Offline Godffery
  • Godffery's Garage
« Reply #115 on: May 04, 2018, 09:06:23 PM »
 I'd say it works pretty well together.
A daring move, well executed.  ;)
Offline algophobe
« Reply #116 on: May 08, 2018, 09:45:42 AM »
thanks godfrey. well as nice as that paint was. I always manage to find a way to screw it up. I had a local sign shop cut a vinyl stencil to form the number plate and "Honda" lettering as well as the Chinese character which will be the signature of the bike. I knew they tend to leave glue residue and can come off with some encouragement. but what really ruined things was that I painted white, then masked to paint the black. a single edge with two paint colored layers don't work to well. so I had to wipe it off and start over. fortunately the layer of catalyzed clear on top of the grey and yellow shielded the mistake and can work over it again.
here's the pic of the seat completed since it didn't require too much stencil work. there's a final flow clear coat so it makes it extra shiny. the flow coat was intended to avoid having to do fine sanding and buffing to get rid of minor orange peel, but there are some runs that i'll have to remove so now buff and sanding is a must to finalize the paint.
only the tank remains to be painted. i'm going to have to hand cut transfer/masking films to make the lettering. this is going to be interesting.
« Last Edit: May 08, 2018, 10:09:22 AM by algophobe »
Offline Godffery
  • Godffery's Garage
« Reply #117 on: May 08, 2018, 07:08:19 PM »
No sweat Man, that's just a little thing we call "the learning Curve".    ;)
Offline algophobe
« Reply #118 on: July 11, 2018, 09:37:09 PM »
Haven't posted lately as I have been struggling with painting the last piece of the bike. The gas tank has more layers of artwork and lettering that I had quite a bit of trouble with. specifically painting the Honda letter, the number and surrounding black frame. had some issues with putting on decal stencils that left glue residuals that ended up requiring wiping them off with acetone and starting over. fortunately the clear coat sealed the yellow and grey layers. the last few months of painting had been plagued with bad weather from rain, temps <60, and >120 degrees in Southern California which slowed down my progress. But I've finally finished the paint job. PHEW!!!
I learn a few things the hard way. 1) minimize tape time with decals/stencil and line tapes (it helps reduce glue residues) 2) always buy new vinyl tapes for each project as expensive as they are (if they're old they also leave glue residues) 3) when there are contaminants on the clear coat (fisheyes), check the connectors for the spray guns, even with new moisture/dust filters contaminant hide in plain site.
Offline algophobe
Re: My first complete build 72 CB750 - painting COMPLETE!
« Reply #119 on: July 11, 2018, 09:40:10 PM »
below are some hurdles I sorted, thru. fisheye contaminants, failed vinyl stencils led to trying to make my own stencil, the lettering was horrid.
« Last Edit: July 11, 2018, 09:45:55 PM by algophobe »
Offline algophobe
Re: My first complete build 72 CB750 - painting DONE!!!
« Reply #120 on: July 11, 2018, 09:59:37 PM »
I decided to give the custom cut vinyl decal/stencil another try and breaking down the black elements and painting them separately to minimize tape time, and it worked like a charm! no glue residue
I decided to use the #7 instead of #72 was it would be simpler and less cluttered, 7 being a homage to my wife being the 7th of 8 children.... and the only daughter amongst 7 sons. with all the patience to handle 7 brothers and the many hobbies of her husband.
The black framing was quite another challenge as well, as it was taped by hand and the tight turns pushed the flexibility limits of the masking tape. in the end, i clear coated after all of the black elements were painted, and cleaned up the black and white lines by hand with a fine brush and lettering enamel, followed by a final clear flow coat.
Then sanding from 1500 to 3000 grit and buffing it with cutting compound.  and VOILA!
Its gonna get a little wax tonight and then on to reassembly this weekend.
« Last Edit: July 11, 2018, 11:29:28 PM by algophobe »
Offline Godffery
  • Godffery's Garage
Re: My first complete build 72 CB750 - painting DONE!!!!
« Reply #121 on: July 15, 2018, 08:33:29 PM »
Well done Man!   Painting itself is a real challenge, then to add multi color, stripes AND lettering is an over-achievement for attacking a first time paint project.  Well Done Indeed!!!
Offline algophobe
« Reply #122 on: July 16, 2018, 09:41:52 AM »
Thanks Godffery, though i have to confess, not my first body paint that's why I was ambitious enough to use all the layers, definitely the most complex I've done so far. I used to rattle can paint all my riding buddies' race/track plastics back in the day, i'll post some pics up later when I get home. the two component paints are a bigger headache but gives such beautiful results when you put in the time.
« Reply #123 on: July 16, 2018, 10:11:37 AM »
Good job on the paint. It is reminiscent of the Edwards/Rossi Yamaha livery/helmets used at Laguna Seca
Offline algophobe
« Reply #124 on: July 16, 2018, 11:14:03 AM »
subconsciously maybe inspired by Collin. but this was the main inspiration.
