Author Topic: Need help identifying pistons  (Read 4998 times)
« Reply #25 on: January 15, 2018, 09:35:30 AM »
Dynoman recommend 0.0025” (0.0635mm) for their 1000cc pistons, forged JE 71.25mm.
My old 836 did not smoke with cast pistons and 0.2mm clearance.
That cylinder need CycleX 65.5 mm pistons (849cc).
« Last Edit: January 15, 2018, 11:53:58 AM by PeWe »
Re: Need help identifying pistons
« Reply #26 on: January 15, 2018, 12:00:48 PM »
Man I can't afford to stick a new set of pistons, but then I won't go dragracing the week I put them in..
 But.. someone always has so they plan for it.
« Reply #27 on: January 21, 2018, 08:10:52 PM »
 I got some pistons out if a 78 F model.
 These pistons have a high crown, about 5 mm higher than edge of piston .they are marked 410.
The rods are marked s59 and S50.
 I thought 77/78 had flat tops due to smaller chamber size.. what do I have here ?
Offline smacd11
Offline cbr954
« Reply #29 on: January 22, 2018, 06:55:46 AM »
They are F pistons.  The F had larger combustion chamber then the K's.  The few I have measured have been 5 to 6 cc larger then the K
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline smacd11
« Reply #30 on: January 22, 2018, 07:21:57 AM »
I found a post somewhere that said the 77-8 F's (410) had 28cc combustion chamber, the K0-6 (300) were 22cc, and the K7-8/F1 (392) were 24cc.
Offline cbr954
« Reply #31 on: January 22, 2018, 09:31:45 AM »
Thats about what I found for volumes but they do vary quite a bit from the factory.
« Reply #32 on: January 23, 2018, 11:29:29 AM »
Son of you used the F pistons in an earlier K, you should get a nice boost in compression, I suspect rings may be pricey.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #33 on: January 23, 2018, 12:01:05 PM »
I use to run ‘em in k’s back in my youth
