Author Topic: CB500K1 forks issue  (Read 1443 times)
Offline AndyH
  • My religion:-
  • Pretty well West of Everywhere in Aus!
CB500K1 forks issue
« on: November 22, 2017, 01:10:42 AM »
With the bike on the centre stand, if I pull up on the handlebars the forks make a "clunk" sound as the forks are fully extended.
Do I have a problem with my springs (compressed over time and too short) or is there something else I need to look at?
Thought I'd ask here before dismantling the forks.
Note:  I have not yet checked oil.
TIA
Andy
1971 CB750K1 (US import)
1972 CB500 Four K1 (SOLD)
Previously owned..
1967 Honda Sports 90
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1983 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
Offline Scott S
Re: CB500K1 forks issue
« Reply #1 on: November 22, 2017, 03:53:54 AM »
 Are you sure it's the forks and not the steering stem/triple trees? Is the steering stem nut torqued correctly and bearings good?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline AndyH
  • My religion:-
« Reply #2 on: November 23, 2017, 12:52:18 AM »
Definitely the forks Scott.  Stem nut & bearings all good.
Previously owned..
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1983 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
« Reply #3 on: November 23, 2017, 02:16:35 AM »
My front used to be stone hard, until I changed to Shell Advance 7,5 weight, which happens to be the same viscosity as the prescribed ATF. 10 would seem to be the max and I certainly wouldn't use 20. Multigrade must be a joke as the fluid never ever gets that warm. To my surprise I have read some use motoroil. We were always warned to stay away from that being not compatible.
« Last Edit: November 23, 2017, 02:22:54 AM by Deltarider »
Offline AndyH
  • My religion:-
« Reply #4 on: November 23, 2017, 02:31:45 AM »
See my response in the other forum.
Previously owned..
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1983 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
« Reply #5 on: November 23, 2017, 03:31:02 AM »
I always try to be helpful. First sign of helpfulness: read your Owner's Manual. ;D p.73 http://www.honda4fun.com/pdf_libretti/500/CB500_k1/CB500_K1_3.pdf Furthermore I'm pretty confident you'll find 7,5 w. front fork oil in a motorcycleshop in AUS. I have a clunk sound when I pump my forks. It has always been like that. Could be the locked brake which sound maybe resonates upwards, could be the springs that contact the inner side of the tubes. Who knows? I find it not very useful to comment on what you may hear, simply because I can't hear it here and so are not able to judge it. Also my CB500 front legs almost certainly differ from yours, Sir. Sorry I could not be of more help to you. I can only hope you will accept my humble apologies.
« Last Edit: November 23, 2017, 03:43:56 AM by Deltarider »
Offline AndyH
  • My religion:-
« Reply #6 on: November 24, 2017, 01:27:52 AM »
Hi DR, I appreciate your response, and apologise if some of my remarks appear a bit argumentative.
Of course, in AU we have several fork oil brands, what I was trying to say was that EU brand names may not necessarily be represented in AU.  Motul, Castrol and Penrite are the "local" main players.
I'll go with Penrite 10W and see if that minimises the "clunk" (which appears to be more common than not on these bikes... ???  ).
« Last Edit: November 24, 2017, 02:20:57 AM by AndyH »
Previously owned..
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1983 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
