Author Topic: having issues  (Read 1580 times)
Offline dusterdude
having issues
« on: January 02, 2007, 06:04:24 AM »
all of a sudden i am having issues with my window size when reading the forum.i cant keep it full screen because i read it at work.prior to last friday i could read it at about 1/3 of a full window size.now i really have to stretch the window to be able to read the posts without moving the threads back and forth.any ideas?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
Re: having issues
« Reply #1 on: January 02, 2007, 06:29:39 AM »
          I wish I could be of help but, I'm just barely able to take care of myself, when it comes to PCs. :(
     Hope someone chimes in soon to give you some relief.
                                                      Later on,  Bill :) ;)
Member # 1969
Offline Bob Wessner
  • "Carbs Suck!"
Re: having issues
« Reply #2 on: January 02, 2007, 06:54:23 AM »
DD, when you resize the window, how do you go about it, do you use the buttons at the upper-right or do you just drag the borders? Oh, what browser do you use, I guess that would be a good question to ask.  ;)
Offline Klark Kent
Re: having issues
« Reply #3 on: January 02, 2007, 09:33:22 AM »
try sizing the window how you like it and shutting down the program- then reopen the program and your window should be that size again.  most browsers remember the last size window and open up the next time the same way.  most likely the last window you had open was a pop-up and the browser thinks that is the prefered size.  hope this helps
-KK
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
Offline heffay
Re: having issues
« Reply #4 on: January 02, 2007, 09:34:56 AM »
in the view pull down menu find text size... adjust accordingly to suit your needs  ;)
Offline Klark Kent
Re: having issues
« Reply #5 on: January 02, 2007, 09:44:24 AM »
ahhh, misunderstood the question (i.e. didnt bother reading all the words)
what heffay said
-KK
-KK
75 CB550k
95 KLR650
you'll feel better.
Offline dusterdude
Re: having issues
« Reply #6 on: January 02, 2007, 11:43:18 AM »
heffay,text size is the same for all open windows,ill play with the window sizing and see if that helps,this is very perplexing.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline heffay
Re: having issues
« Reply #7 on: January 02, 2007, 11:54:26 AM »
so, um... try and restate your question... i'm still a bit confused as well.
Offline Dawdlin Dog
Re: having issues
« Reply #8 on: January 02, 2007, 12:23:29 PM »
Do you mean you are getting a scroll bar at the bottom of the window?
My bike can be repaired.
My insanity is a little more permanent.
Offline dusterdude
Re: having issues
« Reply #9 on: January 02, 2007, 12:32:12 PM »
zactly,previous to this anamoly,i could size the window any way i wanted and i didnt have to scroll at the bottom.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Klark Kent
Re: having issues
« Reply #10 on: January 02, 2007, 12:44:17 PM »
there is a limit to how small you can make the window and get the carriage return effect with no scroll bar at the bottom.see if making the window a little bigger gets rid of the scroll, because i checked and the preferences for IE do not turn this function on and off- it seems to be always on, but limited to a certain window size.
-KK
-KK
75 CB550k
95 KLR650
you'll feel better.
Offline Uncle Ernie
Re: having issues
« Reply #11 on: January 02, 2007, 01:26:22 PM »
Get a different job.
Offline Dawdlin Dog
Re: having issues
« Reply #12 on: January 02, 2007, 03:42:10 PM »
The usual reason for this is a graphic image that is to big for the screen.
For example if the advertising banner towards the top of the page has been set to display at a fixed number of pixels and not a % then when you size the window to a lower number of pixels than the graphic is set to display at you will get the scroll bar.
This is something that is written into the board software and there is nothing you can do about it.
If this has only started recently then possibly the board developers have updated the software recently.
This might not be the case here but its the usual one.
p.s. I know nothing about computers really. I asked my partner who is a programmer ;D
Offline heffay
Re: having issues
« Reply #13 on: January 02, 2007, 03:46:50 PM »
dawdlin... i was just wondering... have you ever been mistaken for a nerd?   :)
edit: oops didn't see you last line... you should ask your honey.  hehe snicker
« Last Edit: January 02, 2007, 03:48:55 PM by heffay »
Offline Klark Kent
Re: having issues
« Reply #14 on: January 02, 2007, 03:47:07 PM »
yeah, for me it happens when the "The Single Overhead Cam 4 Forums" and the logo dont fit on the same line.  since that is a text object, then heffays original advice of making the text smaller is the only way to get the window to get smaller without horizontal scroll. who's the nerd now?
-KK
-KK
75 CB550k
95 KLR650
you'll feel better.
Offline Dawdlin Dog
Re: having issues
« Reply #15 on: January 02, 2007, 05:28:11 PM »
I asked her, She said "Nerd? No. Nutter? Yes"  :D
Re: having issues
« Reply #16 on: January 02, 2007, 05:35:14 PM »
I've had the same problem from time to time, not just on here though ???
Sam.
