Author Topic: 78 CB750 aftermarket wire harness  (Read 1805 times)
Offline Wbflyer
« on: December 08, 2017, 11:56:21 AM »
Trying to figure out where to attach and lay thing out on the bike.  It's different from the OEM. Anyone have pics of a new aftermarket harness on the frame?
Thanks!
Offline Wbflyer
Re: 78 CB750 aftermarket wire harness
« Reply #1 on: December 08, 2017, 03:06:53 PM »
The harness is from Vintage CB750
Offline CycleRanger
  • No comment about being an
« Reply #2 on: December 08, 2017, 03:52:28 PM »
Here's the diagram from the manual.
(Available here: http://www.honda4fun.com/materiale-documentazione-tecnica/shop-manual )
This is for the earlier K models but should get you close.
What's different about the new harness?
Offline Wbflyer
« Reply #3 on: December 08, 2017, 08:55:43 PM »
When I lay mine by the OEM , they are not close in length and connection locations.
« Reply #4 on: December 08, 2017, 08:56:24 PM »
If your new harness was intended for the "F" bike, there may be a branch (wye) with some wires that were intended to junction in a small, triangular wiring housing at the front lower left frame, under the tank, in front of the engine. If it is for the "K" model, this will not be the case.
Offline Wbflyer
« Reply #5 on: December 09, 2017, 12:03:24 PM »
Ok, got it!  It's not a F bike so it should be correct.  The issue is that I got the bike without the harness on it so I do not have a reference to know where it should go onto the bike.  here is a pic of how I laid it out.
Offline Desert-SOHC
  • It's old
« Reply #6 on: December 09, 2017, 08:15:14 PM »
When I changed mine there harness worked fine.  Follow the diagram
« Last Edit: December 09, 2017, 08:19:25 PM by Desert-SOHC »
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline CycleRanger
« Reply #7 on: December 09, 2017, 09:02:44 PM »
You have a lot more parts to add before you're ready for the wiring!
Add some more pieces and it will make more sense. :)
Offline Wbflyer
« Reply #8 on: December 10, 2017, 10:36:04 AM »
You're probably right, I will wait.  I thought it would be easier to wire with less on it but might be creating more frustrations than needed.
« Last Edit: December 10, 2017, 12:28:04 PM by Wbflyer »
