Author Topic: Holy hot tub batman!  (Read 4037 times)
Re: Holy hot tub batman!
« Reply #25 on: March 05, 2018, 07:50:27 PM »
So I'm thinking you have at least one 110V outlet in the basement location? And you have ONE breaker slot left?
110V existing in the basement + 1 open breaker slot (another 110V breaker you're thinking). That sounds like the recipe for a 220V breaker (ie 2 X 110V = 220V) and a line to the tub. Might be able to do it easier than you think.
Offline eigenvector
« Reply #26 on: March 05, 2018, 08:00:55 PM »
We'll see.
I don't want anything iffy or marginal.  Top quality or nothing, last thing I need is to burn down the house, turn the hot tub into a portable electrocution chamber, or get slammed by the inspector.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline jlh3rd
  • "just who gets to determine my needs?
« Reply #27 on: March 06, 2018, 02:49:46 AM »
We'll see.
++1
"alleged greed is usually a lazy person's opinion"
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #28 on: March 06, 2018, 05:52:08 AM »
My meter box outside, which connects to the weatherhead, has a 200amp meter in it. Check your meter first, to see what is needed to upgrade your service to a 150 or 200amp service panel inside. If you have a 200amp meter (new digital ones are all 200 I believe) Then check the gauge wire coming into the panel from the meter. If it is the correct gauge for your new panel, all you would have to do is pull the meter, (notify the electric company of doing this) and then replace your 100amp panel with either the 150 or 200amp panel.
Menards has great sales on panels, and breakers, that is what my daughter (electrician) and I did to upgrade my home panel for the kitchen remodel with a wall oven/microwave combo, and an induction stovetop in the counter, both of which took 40 amp 220v breakers. It took a couple hours to replace the panel, re-hook all the wiring that was removed from the old panel, and connect up everything.
Now, if your meter isn't a 200amp rated meter, then you will have to have an electrician look at the service drop and weatherhead connections to the meter box, and see if you need to upgrade them too. Mine was old, but still had rated wiring from the pole into the meter, and into the panel. Yours may be also! I have about 5 or 6 unused breaker locations, as I purchased a long-a** panel to hang in place of the old one, and I can add more circuits as time goes by... :)
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
« Reply #29 on: March 06, 2018, 09:21:24 AM »
 More Power To You.....
Offline eigenvector
« Reply #30 on: March 06, 2018, 04:33:59 PM »
Just got done with the contractor.
220V service and a new panel.
He also recommended an venting system to keep the moisture down - so now I have to do some research on that.
Rob
1977 CB550K
1983 VF750S Sabre
