Author Topic: It is always something...  (Read 1341 times)
Offline glenncal1
« on: March 14, 2018, 10:18:00 AM »
Fixed the oil leak (new valve cover gasket), now the #1 carb (I think) is leaking out overflow tube. Was kind of looking forward to leaving the tools in the chest this weekend. Guess not.
And yes I would like some cheese with that whine  :'(
Offline Flyin900
Re: It is always something...
« Reply #1 on: March 14, 2018, 10:35:39 AM »
I maybe just a little junk in the needle seat area. Try flushing the offending carb by draining the float bowl and refilling a few times and it may flush the seat enough to correct the issue.
Worst case I have used my small compressor reduced down to about 30 lbs pressure on the gauge and opened and drained the offending carb leaving the drain screw out. Pulled the inlet gas hose on the carb rack from the petcock and blown compressed air through the system and it usually dislodges anything from the float seat area. Its good to place a rag around the drain hole on the carb to catch any gas spray. Cold engine is also a good thing to start with too, as you have gas fumes around the motor for a few seconds.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
« Reply #2 on: March 14, 2018, 11:43:13 AM »
If working on your old vintage bike isn't fun on some level.  You should not have it, imo, as it now owns you.
If it is just another tool to move your butt from A to B.  Modern ones with warranty service do that without you having to do any work on it.
Perhaps you need to revisit your priorities?  Vintages bikes are never finished with routine maintenance.  If that makes you miserable, why have it at all?
I dare you.  List all the reasons why you still own this bike.
Offline RandomOrbit
« Reply #3 on: March 14, 2018, 11:58:36 AM »
It's true. it IS always something. Part of me would like to have a newer bike that required less tinkering. Much as I do enjoy the tinkering to some extent, sometimes I just wanna ride. That said I'll never get rid of my CB750, so a newer lower-maintenance bike would have to be a second bike, not a replacement.
CB750k6 owned since 1991
Offline glenncal1
« Reply #4 on: March 15, 2018, 10:10:01 AM »
Didn't say I was miserable, I like working on the bike and have many old bikes (mostly of the dirt/dual sport variety), just saying it's always something. My house is the same way and it is only 10 years old. I like the bike better  ;D
Offline Johnie
« Reply #5 on: March 15, 2018, 11:11:37 AM »
I agree...life would be pretty boring if "it was NOT always something". :) Although I have to admit my 750's once done have been pretty maintenance free...better not say that to loud.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #6 on: March 15, 2018, 01:24:57 PM »
...but maybe not upgrade/modification and back again free! ;)
« Reply #7 on: March 16, 2018, 12:26:36 AM »
Buy at least one modern-ish bike mate, for days when you want to ride and your SOHC4 is pissing you off, I've got lots of bikes so if one is pissing me off it's nice to just be able to jump on another one, rather than going mental and shooting it with my old .50 cal rifle. ;D
« Reply #8 on: March 16, 2018, 07:37:15 AM »
+1...but doesnt have to be "modern-ish", buy a [GASP!] Kawasaki!
« Reply #9 on: March 16, 2018, 08:02:15 AM »
or -- GASP-- a Suzuki
Offline beemerbum
« Reply #10 on: March 16, 2018, 08:24:24 AM »
+1. However a fine motorrad from Bayrische Motoren Werke will serve you well.
« Reply #11 on: March 16, 2018, 02:20:27 PM »
Yep, I have to choose from  a Triumph, Harley, 2x BMW's, a Yamaha or 5 Honda's, and there might be Suzuki on the horizon, so always something interesting to ride. Old bikes are fun, but modern (big) bikes are awesome. ;D
Offline glenncal1
« Reply #12 on: March 17, 2018, 06:19:31 AM »
I have a 1993 Nighthawk that I was going to fix and flip. Turns out it didn't need fixing, kept it to have until I get the 350 fully sorted out. Plus I kind of like it.
« Reply #13 on: March 17, 2018, 07:19:05 AM »
 If it's not that one thing it's lint in your belly button. Always something.
« Reply #14 on: March 17, 2018, 12:18:27 PM »
need bigger garage for more bikes
