Float valves replaced, heights set to 26mm just touching the spring pin, sprayed the idle passageways out again, sealed around the bungs just above the idle jets with seal all, replaced the larger torque clamps with 44mm Honda ones. I checked the fuel level via the clear tube method and had 3mm below the mating surface on 3&4 and 7m on 1&2. I triple checked all of them before mounting the carbs but oh well.
Still won’t start or run with choke unless I’m on the throttle the entire time and it sounds like it’s bogging down when I did keep it going with throttle, choke off and it peps up immediately just have to turn tbe idle screw up until it’s warm, then slowly back it down.
But! Eureka! As soon as it was warm I dropped it down to 1100 and it held there great! No strange popping, both 4-2 pipes have the same tone. All four plugs were... beige? Very light tan. Pic below.
Before I sync the carbs again, should I head straight to adjusting the 1&2 floats higher? Since it started and the plugs all look the same, should I just turn the air screws on 1&2 in to about 1/2 turn and ride it for a bit to see if the fuel level in 1&2 catches up eventually?
Lastly, any guesses as to how to get the choke to work as it should?
