Author Topic: Cracked tube solution  (Read 1973 times)
Offline 78whiteorbs
« on: April 06, 2018, 09:40:57 AM »
Okay okay so check the picture out this cracks are in an Autolite 2150 carb off an F100! Yes yes I know not a bike but the emulsion tube is exact same kind of brass tube that is in a petcock for the Reserve I have tossed dozens of those and had to replace them for those splittings. For this particular carb you can't get just that part you would have to get the whole carb so I'm wondering what's the best way to fix this. I've dodged a bullet so many times on the petcocks I would know by now if I wouldn't have just replaced it hahaha
Offline Scott S
Re: Cracked tube solution
« Reply #1 on: April 06, 2018, 10:03:59 AM »
 With those being emulsion tubes, I'd be very sceptical.  The overflows are just that. Just a tube. I've used JB Weld successfully.  Some have shrunk a plastics tube over the crack. But those emulsion holes are gonna throw you a curveball.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline 78whiteorbs
« Reply #2 on: April 06, 2018, 10:55:05 AM »
Only holes at the bottom Scott. It hasnt split that far yet!.
I was thinking fuel proof jb or solder.Admittedly the jb route is more my area of expertise. Anybody else have fuel proof plan? Lol Would heat shrink not just melt. Its not constantly immersed.
Offline Paintedseat
« Reply #3 on: April 06, 2018, 11:10:18 AM »
Solder and flux first. If not than JB.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #4 on: April 06, 2018, 01:02:40 PM »
IDK about heat shrink tubing, but people use brass tubing that can be purchased from craft and hobby shops to repair the carb overflow pipes. I would think you could use something similar in this situation to reinforce the tubes.
« Reply #5 on: April 06, 2018, 01:16:51 PM »
They are very easily soldered and solder will last.
« Reply #6 on: April 06, 2018, 01:39:59 PM »
+1, solder is the only way to go. ;D
Offline Airborne 82nd
« Reply #7 on: April 06, 2018, 01:46:11 PM »
If you don't feel good doing it any good AC tech. can do it for you.  :)
Offline 78whiteorbs
« Reply #8 on: April 07, 2018, 12:20:11 PM »
Solder did the trick! Practiced on an old petcock first. Skills aquired! Used a little sandpaper to thin it down afterward on the truck carb. Wouldnt be needed on a reserve tube though. Cheap fix!
« Last Edit: April 07, 2018, 12:23:59 PM by 78whiteorbs »
Offline Paintedseat
« Reply #9 on: April 07, 2018, 04:45:02 PM »
Looks good. Last another 40 years
« Reply #10 on: April 08, 2018, 11:15:34 AM »
Congratulations!
