Author Topic: steering head taper bearings  (Read 538 times)
Offline billbill
« on: April 06, 2018, 04:30:06 PM »
Hi   i am new to this site  and this is my first post   i am in the process of fitting taper head stem bearings   and i find the top outer cone is sitting  higher than the original  as its  deeper  so it protrudes  about 4mls above the headstock  is this normal or have i got the wrong bearings   also there is a spacer supplied with the bearings  and i assume it goes under the lower bearing thanks
Re: steering head taper bearings
« Reply #1 on: April 07, 2018, 02:37:04 PM »
Welcome.   You dont state what bike you have or which spacer you installed?
Here is the tapered bearing thread, give this a read and should answer all your questions....
http://forums.sohc4.net/index.php?topic=1516.550
