Author Topic: Big valve upgrade  (Read 2415 times)
Offline fireman1073
Big valve upgrade
« on: April 19, 2018, 02:34:20 PM »
Ok so I bought a Thompson big valve kit from a guy on Craigslist
He said it should fit a 75 cb750
They look kinda too big     I don’t know
What kind of machine work do I need to do to the head for this?
I put a piston next to the valve and I don’t know how this could work
The seller claimed Big horsepower gains with these
Offline DV Red Herring
  • Army RETIRED
Re: Big valve upgrade
« Reply #1 on: April 19, 2018, 02:44:54 PM »
Another great Craigslist find... haha
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2 on: April 19, 2018, 02:55:01 PM »
 8)
Offline Paintedseat
« Reply #3 on: April 19, 2018, 04:18:04 PM »
You have to change the valve timing. You have to install a much smaller cam gear so the valve will have to open twice and act as a intake and exhaust valve. It's a simple upgrade.
« Reply #4 on: April 19, 2018, 05:32:58 PM »
Backcut that valve if you want to make some better low lift #'s.
« Reply #5 on: April 19, 2018, 09:18:53 PM »
 Ha ha - that thing is huge. Any idea what it was used on ?  I bought a big cool valve once still in its original box at a yard sale that was used on B-29 bombers. Not as big as yours though !
« Reply #6 on: April 19, 2018, 10:23:21 PM »
 I have a Neway valve seat cutter, I think we may need new seats though.
« Reply #7 on: April 20, 2018, 03:20:40 AM »
Look heavy.
A good port job is no1. Work fine with stock valves and guides.
Next is Kibblewhite 5mm valve kit, 34mm In and 28mm Ex if an K head. Port job for the bigger valve to use the bigger area. Maybe together with bee-hive springs.
I think this is called JMR Porting stage 4 head ;)
Offline Flyin900
« Reply #8 on: April 20, 2018, 04:10:12 AM »
 When I installed one of those the biggest issue was the spring compressor to install the keepers. Needed a backhoe with the compressor attachment.  :o
« Last Edit: April 20, 2018, 04:11:53 AM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline fireman1073
« Reply #9 on: April 20, 2018, 07:01:24 AM »
i think it came from a commercial fishing boat
« Reply #10 on: April 20, 2018, 02:20:02 PM »
Rieck's the only guy I know that could make that work  ;)
Offline gschuld
« Reply #11 on: April 20, 2018, 04:27:57 PM »
They would made good bases for a table lamp.😉
George
Offline CarbonK
« Reply #12 on: April 27, 2018, 08:04:05 AM »
I’ll let yah borrow my micrometer if you need to take some measurements.
« Reply #13 on: April 27, 2018, 08:28:20 AM »
For viagra guys!
Offline RJ CB450
« Reply #14 on: April 27, 2018, 08:46:56 AM »
Think might run into one problem.  That doesnt look like a metric valve...  You gotta bore and stroke to get it to the 45 ci required.  Dont forget you will also need imperial pistons too.
74 CB450 K7 Supersport, 82 CB650sc Nighthawk, 1982 CBX 1000, 2015 Tiger XCx.... And some ol minibike with a 5hp Briggs.
« Reply #15 on: April 27, 2018, 11:21:50 AM »
Nice set of calipers there CarbonK, I like that storage box. What kind of latches does it have?
I like a nice wooden case or box...even if simple...beats the heck out of plastic every day, every way...
David
Offline CarbonK
« Reply #16 on: April 27, 2018, 12:27:45 PM »
David
Haha, I’d love to tell you but it’s just an image I came across online which reminded me of this thread.
