I think I agreed with eli that he will test the solution. He has everything ready including CB750A crank.
My plan is to ship all the components in one month time to eli.
For people interested in CB900 crank.
I realized(forgot) that I need to make also primary sprocket dumber specially for CB900 crank. It is just matter of different number of tooth because cb750/cb750A has 24 tooth on sprocket vs cb900 28 tooth.
So I will not loose time there.
for my build I will use cb900 crank actually... but different topic...
I am sorta thinking..
Racing a monster motor and changing the Hyvo every race.
I am thinking 5 to 8 or ten races. 3 hours minimum to change it out. Adds up fast looks like 1500 to 3000 a season just to keep chains in it......ouch...
I got the point that it was "every race" not every meeting.
The last time we ran a chain it lasted for practice and qualifying, one race and two laps of the next (the chain was brand new HD race spec and so was the manual tensioner).
Admittedly this was at Spa in Belgium and a sustained high speed track which amplified the effects but it was the final confirmation of the ever reducing chain life we were experiencing with each increase of RPM and HP. The resulting damage of this final failure was approx 50% of the engine destroyed (and we got away lightly). To repeat and remain with a chain and accept the risk is totally unrealistic and foolish unless both HP and RPM are reduced. To have arrived at the point that we have this problem is actually a success and from which I will not retreat and so the Gear Drive was born.
The point here is that Silent Chains have a speed limit and when combined with high HP and high RPM are just not viable for any serious durability expectations.
Captain
Captain can we get one advice. Do you think that idler sprocket bearings should get feed of oil directly from oil pump or there is enough oil around floating and bathing the bearings ?
The operational loads are too high (even using hybrid ceramic bearings) not to have a dedicated oil feed for both cooling and lubrication. In my DOHC install I do this by drilling a small hole (.8mm) in the main oil passage as it passes by the idler. The resulting jet is directed at the idler gear bearings.
Captain
Thanks Captain. I am planing to add feed from return line. I will use 0.8mm like you recommended.
But is there a restriction on the other side or is it also 0.8mm? And because there are two bearings do you feed oil just on one side of two bearings combination ?
