Author Topic: Geared Primary Drive  (Read 50642 times)
Offline Captain
Re: Geared Primary Drive
« Reply #75 on: March 06, 2019, 02:08:36 AM »
I am sorta thinking..
Racing a monster motor and changing the Hyvo every race.
 I am thinking 5 to 8 or ten races.  3 hours minimum  to change it out. Adds up fast looks like 1500 to 3000 a season just to keep chains in it......ouch...
 I got the point that it was "every race" not every meeting.
  The last time we ran a chain it lasted for practice and qualifying, one race and two laps of the next (the chain was brand new HD race spec and so was the manual tensioner).
Admittedly this was at Spa in Belgium and a sustained high speed track which amplified the effects but it was the final confirmation of the ever reducing chain life we were experiencing with each increase of RPM and HP.   The resulting damage of this final failure was approx 50% of the engine destroyed (and we got away lightly). To repeat and remain with a chain and accept the risk is totally unrealistic and foolish unless both HP and RPM are reduced. To have arrived at the point that we have this problem is actually a success and from which I will not retreat and so the Gear Drive was born.
The point here is that Silent Chains have a speed limit and when combined with high HP and high RPM are just not viable for any serious durability expectations.
 Captain
Offline MessnerMoto
« Reply #76 on: March 06, 2019, 10:21:13 AM »
Anything new?
I don't have engine to put it in. I reached to several members if they want to join in. There was no real interest.
Anything new?
+1 ??
+1 ???  900 idler ???
idler carrier and 900 idler can be made easily also
Offline T1m32sh1n3
« Reply #77 on: March 06, 2019, 03:54:31 PM »
Hell, I'd like to try it in a street engine.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #78 on: March 06, 2019, 05:18:41 PM »
me too
« Reply #79 on: March 06, 2019, 10:33:15 PM »
me too
Anything new?
Anything new?
+1 ??
Mirko,
I'm interested in a 900 crank version for the street. Too old to RACE, then it would be a struggle just to be below average.....😩  I need to p...m... you anyway. I'll try Monday after I get back from Lincoln Nebraska
Thanks for your Toil Mirko..
Offline MessnerMoto
« Reply #80 on: March 07, 2019, 01:35:36 PM »
pm who is interested ;)
Offline dragracer
  • CB750F Dragbike
« Reply #81 on: March 07, 2019, 02:18:24 PM »
If I could afford it, I would certainly throw my hat in the ring for a set to install in a drag race engine. Cost is a factor but i'll send a PM anyway.
Online scottly
« Reply #82 on: March 07, 2019, 05:57:39 PM »
Offline T1m32sh1n3
« Reply #83 on: March 07, 2019, 05:59:31 PM »
Why not
Online scottly
« Reply #84 on: March 07, 2019, 06:12:45 PM »
First, the stock primary chain is adequate for a street bike for over 100,000 miles. Second, to use the gear drive, you must first switch to the Hy-vo, or Silent type chain drive crankshaft and primary shaft, which is even stronger than the original primary chain. As Captain alluded to, in his case chains can't handle the extreme RPMs he is running. You will not see 14,000+ RPM on a street bike. ;)
Offline T1m32sh1n3
« Reply #85 on: March 07, 2019, 06:41:02 PM »
Good points
« Reply #86 on: March 08, 2019, 09:19:46 AM »
 I am interested too.
Offline teebee67
« Reply #87 on: March 08, 2019, 11:42:38 AM »
Me too.
I'm only old on the outside.
Offline MessnerMoto
« Reply #88 on: March 08, 2019, 01:17:53 PM »
that 100k miles will depend on how you drive it.
Ok I see there is interest
the best way how to proceed is that I finish all the parts and then send them to person who is closest to actually testing it
Offline gschuld
« Reply #89 on: March 08, 2019, 02:07:51 PM »
I have interest in this also once it has been tested.
George
Offline T1m32sh1n3
« Reply #90 on: March 08, 2019, 02:51:01 PM »
I'm far from ready
« Reply #91 on: March 08, 2019, 08:27:02 PM »
 I'm following what Tracksnblades1 does.
Offline MessnerMoto
« Reply #92 on: March 10, 2019, 12:54:24 AM »
Is there anybody out there how is very close to finishing then engine(testing) and also would use CB750A(auto) crank ?
I can finish and provide system fast in that case.
Offline MessnerMoto
« Reply #93 on: March 10, 2019, 01:47:56 AM »
 Captain
Captain can we get one advice. Do you think that idler sprocket bearings should get feed of oil directly from oil pump or there is enough oil around floating and bathing the bearings ?
Offline Captain
« Reply #94 on: March 10, 2019, 03:51:16 AM »
 Captain
  The operational loads are too high (even using hybrid ceramic bearings) not to have a dedicated oil feed for both cooling and lubrication. In my DOHC install I do this by drilling a small hole (.8mm) in the main oil passage as it passes by the idler. The resulting jet is directed at the idler gear bearings.
 Captain
« Reply #95 on: March 10, 2019, 04:32:14 PM »
 Captain
 Captain
Captain,
Do you use a single or two bearing set up In your idler gear.  Not to purposely divulge any of your secrets, but, did you employ oil jet piston cooling on your Max-effort Dohc engine..?
Thanks and for your service too.
TB1
« Last Edit: March 10, 2019, 10:42:47 PM by Tracksnblades1 »
Offline Captain
« Reply #96 on: March 11, 2019, 03:53:56 AM »
 Idler has two bearings and an oil feed via a jet as stated earlier.
 As for the piston cooling................No it relies on splash and I monitor the pistons closely and to date there has been no evidence of any problem.   Also I am running 3D ignition and as this reduces piston temps it is obviously a factor.
 Captain
Offline MessnerMoto
« Reply #97 on: March 11, 2019, 05:18:30 AM »
I think I agreed with eli that he will test the solution. He has everything ready including CB750A crank.
My plan is to ship all the components in one month time to eli.
For people interested in CB900 crank.
I realized(forgot) that I need to make also primary sprocket dumber specially for CB900 crank. It is just matter of different number of tooth because cb750/cb750A has 24 tooth on sprocket vs cb900 28 tooth.
So I will not loose time there.
for my build I will use cb900 crank actually... but different topic...
 Captain
 Captain
Thanks Captain. I am planing to add feed from return line. I will use 0.8mm like you recommended.
But is there a restriction on the other side or is it also 0.8mm? And because there are two bearings do you feed oil just on one side of two bearings combination ?
Offline Captain
« Reply #98 on: March 11, 2019, 11:39:10 AM »
From one side is enough as long as the oil Jet is directed low enough as centrifugal force flings it outwards. This also sends it towards the other bearing.
It has certainly been sufficient in my experience.
 Captain
Offline MessnerMoto
« Reply #99 on: March 11, 2019, 01:19:31 PM »
 Captain
thanks! I have everything now
