Author Topic: I'm glad I decided to check the front wheel bearings...  (Read 744 times)
AwesomeCB
« on: May 12, 2018, 11:20:25 AM »
After replacing the wheels on my K6, I figured I would refurb the wheels that came on the bike with new bearings. It's a good thing I did. This is the bearing on the left side of the front wheel. Someone punched a few holes in it when they (cough) installed it. For good measure, they stripped the threads for the retaining ring so the hub is toast.  Thank God I put only a few miles on the bike before putting on the new wheels. Stuff like that is what gets you killed.
Offline Johnie
Re: I'm glad I decided to check the front wheel bearings...
« Reply #1 on: May 12, 2018, 11:43:28 AM »
Wow...good catch there. Because of this kind of stuff I change out all wheel bearings. Plus, now they are sealed and should never have to replace them again.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #2 on: May 12, 2018, 02:19:42 PM »
that looks like a shielded bearing?more used at the brush end of electric motors?
« Reply #3 on: May 12, 2018, 08:56:15 PM »
It us a shielded bearing, won't keep water out very well.
 Btw, pretty sure if you ran no retainer, you would never notice.
 Morris wheels have no bearing retainers.
AwesomeCB
« Reply #4 on: May 13, 2018, 02:46:41 AM »
Got that right. I cleaned out the rust and metal bits for the picture.
