Author Topic: retrofit choke assembly  (Read 898 times)
Offline MetroRedneck
« on: May 14, 2018, 03:48:17 PM »
Anyone ever retrofit a lever choke assly to a set of 46 carbs (78 550) from and earlier model?  Want to remove the cable assembly entirely.  Bore the same?
Offline DaveBarbier
Re: retrofit choke assembly
« Reply #1 on: May 15, 2018, 05:07:10 AM »
I entertained the idea for a bit but I ended up relocating the choke knob. After that I didn’t like it so I put in a bored out 650 motor with hotter cam, stage 2 porting and race carbs with a choke lever. :))
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2 on: May 15, 2018, 05:10:22 AM »
It wouldn't be as simple as a retrofit. It would be far easier to source pre-77 K or any year F carbs.
« Reply #3 on: May 15, 2018, 08:32:13 AM »
Seems like the best option!  I am waiting on a deal to come along and I'll be doing the same.
I think I will take my spare choke linkage and see if I can braze or thread additional length on it to get it long enough to come out of the carb body.  From there I can manage some type of control lever.  Might need to redo the spring function in the middle, but I think it will be fine.
« Last Edit: May 15, 2018, 09:32:25 AM by MetroRedneck »
Offline DaveBarbier
« Reply #4 on: May 15, 2018, 08:52:32 AM »
If it ends up working out well, post back what you did and how it functions.
« Reply #5 on: June 05, 2018, 12:04:01 PM »
While I believe the earlier choke assemblies will fit the 46C housings, before I start tear down, I bought a set of what should be 627B carbs with a manual choke.  I may just swap and start tuning these.
« Last Edit: June 05, 2018, 03:22:27 PM by MetroRedneck »
« Reply #6 on: June 05, 2018, 12:20:42 PM »
yeah just put early carbs on it,youll need the intake runners aswell.
Offline Deltarider
  • I'm back
« Reply #7 on: June 05, 2018, 12:28:12 PM »
Yeah, that's what I would do.
CB500K2-ED Excel black
« Reply #8 on: June 06, 2018, 12:01:36 AM »
and cables.
