Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
It will probably be difficult to find a screw the right length, with the right thread with a head that narrow. You might be able to modify an off the shelf screw.Curious how you broke that screw? I've had the carbs apart on my F0 a few times now, including removing the tops to make adjustments to the needles and I'm not sure how that would get broken.Anyways, here's a guy in the U.S. selling a used one:https://www.ebay.co.uk/itm/73-Honda-CB750-Carburetor-Throttle-Rod-Set-OEM-Carb-Linkage-Bar-Link-Slide/322014561124?epid=1224102009&hash=item4af9904364:g:GloAAOSw7PBTn3n0
