Author Topic: Stuck Phillips Bolts  (Read 6042 times)
mongeon
Re: Stuck Phillips Bolts
« Reply #25 on: June 17, 2005, 11:32:19 AM »
I don't know much about tools.  An impact driver is essentially a power drill/screwdriver that also pushes down, right?  What do you need the mallet for?
Offline Flood
« Reply #26 on: June 17, 2005, 11:48:20 AM »
No, we're talking not about a electric/compressed air driven tool. This is something like a fat, massive, screwdriver that you whack with a heavy hammer. This not only makes it turn a little, but also momentarily takes the pulling force from the screw (a screw works by pulling its head toward the thread).
As I'm sure a lot of this is lost in my translation, I'll link a pic:
Cheers, Remi
P.S.: If you don't have an impact driver, it may also help to hit on an ordinary screwdriver for the reason described above.
« Last Edit: June 17, 2005, 11:52:34 AM by Flood »
Offline Jonesy
  • Shop Rat
« Reply #27 on: June 17, 2005, 11:49:47 AM »
The impact driver looks like a huge screwdriver. When you strike it with a hammer, it us pushed into the fastener and turns it as well. The shock on the head of the fastener also helps to free it up.
You can see one at: http://www.partsnmore.net/item_index.php?part_unique=2667
