Author Topic: First post! Need help figuring out what spoke wheels fit my bike?  (Read 972 times)
Offline Abzayas
 ;D hey! So I picked up a 1977 CB750 super sport with what from I read here are the Comstar wheels, now I’m looking to go for a brat or cafe style on the bike and feel the Mag wheels need to get replaced with spiked same size wheels.
Does anyone know which years spoked wheels I can fit on my bike with little to no modification?
Re: First post! Need help figuring out what spoke wheels fit my bike?
« Reply #1 on: June 29, 2018, 11:47:00 PM »
little to no modification?...good luck
Offline haynes66
« Reply #2 on: June 30, 2018, 10:41:10 AM »
it would be easier to change complete front end etc rather than find a wheel and adapt everything else to fit which may be too much work for you. have a look at some brat pics and you will see some bikes with comstars painted black. they can look quite cool
« Reply #3 on: June 30, 2018, 08:03:29 PM »
A spoke 750 front wheel will bolt right up to F2/F3 forks, but the brakes are a different issue. Thinned 550 rotors will bolt up to the 750 wheel, but the F calipers will need shimming. In the rear, if you want to keep the rear disc brake, your only option would be an F0/F1 wheel, but I have no idea what would be involved with making it work.
http://forums.sohc4.net/index.php/topic,89771.125.html
« Reply #4 on: June 30, 2018, 08:10:54 PM »
Like Scott says the 6 hold spoke wheels fit.. what we have done is then adapted big floating rotors to the hub and better calipers that require adaptors.
 The F fork is far easier to use for adapting different calipers.
And floating bigger discs are easy to finf to fit the 6 bolt pattern.
 I think I still have a set of adaptors  and calipers around.
 I had built some big brake stuff for the guy with the unzipping avatar... Bert ***
Here is a Big brake Scottly did, it would fit the wire 6 bolt wheel.
« Last Edit: June 30, 2018, 08:33:45 PM by 754 »
Offline Bankerdanny
  • Endeavor to persevere
« Reply #5 on: June 30, 2018, 09:26:28 PM »
The back from a 75-76 F should bolt up easily.  I have a 77 rear caliper on my 76 750F and it works with my spoked wheel with no mods.
I would look for a 75-77 GL1000 GoldWing front wheel. It's twin disk with rear fork lower mounted calipers front the get go, so might need fewer mods. It's also aluminum, so lighter.
Offline Abzayas
« Reply #6 on: July 02, 2018, 07:14:00 AM »
i appreciate all the suggestions and input, definitely going to consider sticking with my wheels in black. Considering this is on a budget and do not want to go crazy throwing money at it.
