Author Topic: Ing/points need help  (Read 1369 times)
Offline Gurp
  • I'm no.......
  • Once was a...
« on: July 04, 2018, 08:49:21 PM »
Setting ing timing. 1-4 set fine and fire strong. 2-3 on the hand...
Spark os week gap is set correctly but when using the circuit tester the light never goes off even when the points touch. The light only dims to half brightness. Not sure what my issue is.
Any help would be appreciated.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline DennyK
  • Just kill the one with the sword first. R. Shaftoe
Re: Ing/points need help
« Reply #1 on: July 05, 2018, 07:04:38 AM »
You might try a new condenser. A friend had a similar thing going on and that fixed the issue.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #2 on: July 05, 2018, 09:34:26 AM »
Its supposed to have a new one on it. Both cons amd the points look new bit its worth a try.
Thank you!
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #3 on: July 08, 2018, 07:44:39 PM »
Condenser fixed it!
